estesbubba
- Joined
- Jul 29, 2014
- Messages
- 20
I have a 30x40 pole that was just completed and was going to use OSB for the ceiling but seems a lot of people use steel. What are the advantages to each?
.....its terrible to paint, doesn't reflect light very well...
........of oil based Kiltz primer on each sheet (had room to paint six sheets at a time) then caulked the edges as I put the sheets up.
I found a drywall jack/lift on craigslist which was the trick since I have 12 ft sidewalls. I had to make leg entenders for the lift since it was 11ft capacity.
..............I really like the look of the painted OSB on the ceiling, but if I had to do it over again I'd go with metal since it would go up so much quicker, I'd guess 1/4 or less of the time I spent on the OSB
