Oscillating Saw and Multi-tool -- Opinions?
paulsomlo
Northern Colorado
What kind of deal did you get? I was hoping to maybe find something and get $50 off just so i could spend that on a blade set. I need the hard case for protection when I have the tool with me at work sites.
I misspoke - I purchased it from Factory Authorized Outlet, via ebay, https://www.ebay.com/itm/Fein-72295264090-Oscillating-Multi-Tool-bag-and-Start-Accessory-FMM350QSL-/172293784794?hash=item281d8284da
It came with a soft sided bag, though. I payed $199, free shipping.
Indexmill
Central NC
The Fein is really a pleasure to use. Incredible difference to the cheapies.
It is so nice to use, I am looking for other uses than undercutting door jambs and replacing window sills. Can folks share other uses?
La Petite Tools
Indiana
I've used ones to cut out siding to make brickmold on a door fit properly, also punch cutting in to replace sections of hardwood flooring. I'm looking forward to also being able to use it for fine sanding awkward pieces that will need to be stained and sealed. It almost seems like anytime I do a job around the house there is always a use for it.
jgromada
Maryland (between DC & Balt)
I own several, I bought a 18v Ridgid jobmax to start with. I really like the changeable heads too. I have several now, including the right angle drill, rotary (think rotozip), autohammer (NLA), and right angle impact. I wanted a smaller tool for the rotary tool so I bought a 12v Ridgid jobmax on ebay. They all get used and they all work fine. Obviously the people that dismiss Ridgid out of hand have not used it. My only observation about the 18v oscillating jobmax tool is that it is quite long and consequently will wear you out a bit if you use it continuously.
I really just wanted the M12 batteries but i got a Milwaukee M12 kit that had their oscillating tool basically for free after i sold the drill that was in the kit. It is ok, but lakes the toolless blade feature the Ridgid has. Its not a huge problem and I basically keep a particular blade on there. Probably the most compact oscillating tool i have and the lightest. For what i have used it for lack of power is not a problem. If i had a deep cut or a lot of sanding I would choose one of my other osc tools.
I also got a 20v Dewalt oscillating tool primarily because of the depth stop tool i have for it. Really like that for cutting out sheet rock and concerned about cutting wires or something behind the wall. It is a quality tool and probably the best oscillating tool i have.
I have never tried the Fein osc tool which i hear is the best but also the most expensive. So i will probably never get one mostly for that reason as i am a homeowner and DIYer not a tradesperson.
kalopsia
I own a Rockwell F80 and a Fastcraft Oscillating tool (~$50 at Costco, came with soft case and accessories), both corded. I found the RW OST blade changeout to be irritating to unlock and turn repeatedly, and usually grab the FC if it’s an easy job.
I picked the RW OST new off eBay, saved almost 40% during a promo earlier this spring.
I use them mostly with wood with good results. Definitely more controllable than a sawzall in tight spots.
Cutting metal dulls the blades too quickly to be cost effective, and is best done with a grinder.
Indexmill
Central NC
We decided to replace all of the 30-year old wooden windows in our house with vinyl and do it ourselves. On the first one, I borrowed a neighbor's Dremel OMT.
OMG, it was awful. It got hotter than hell and killed my hands with vibration.
So, with 23 more windows to go, I bought the Fein OMT... OMG, the difference was night and day. It is almost a pleasure to use. It uses the StarLoc blade attachment system which is expensive, but it cuts like crazy. The carbide tipped blade cuts nails all day long.
If you have any significant amount of use for an OMT, even just as a homeowner, definitely check out the Fein.
SRSemenza
I had the same experience quite a few years ago. I had put off getting an OMT. I knew the Fein was good. In a pinch in the middle of a job I needed one. Went to nearest big box , bought the Dremel. Same result as you had, but it got the job done. In general terrible though. About a year later I picked up the Fein on a super sale. ......................... Yes, night and day. :thumbup:
Seth
