Oscillating tool blades for drywall
pugglewuggle
TX
I just bought a Milwaukee M18 oscillating multi tool. It comes with a wood blade. I cut some wood with it and it works great! Question is: can I use the wood blade on drywall or will it screw up the blade? Should I buy a drywall specific blade? Is there any advantage to a drywall specific blade if the wood blade will work? (Just to be clear, I’m sure it will cut it for a while but I don’t want to burn up the blade if I don’t have to)
Thanks!
WinMod21
Agree ^ All blades work, but like with all sawblades, better blades, like e.g. Bosch, last longer than cheaper blades. And using specific blades for drywall, or metal &c, saves your wood blades from dulling early.
metaldad
nw indiana
you're in michigan. you most likely have a menards down the street. buy a bunch of blades, they're cheap, plus, the 11% sale is still on
dogdog
Best dry wall blade is when those wood or “metal” blades are worn out. When the drywall completely smooth out the toothed , it makes the best caulking scraper. I don’t know what after this. Have not worn our the caulking scraper yet. Maybe Amir will become a lock pick
rlitman
Long Island
My favorite drywall blade is a worn out blade that I cut new teeth into. Just use a cutoff grinding blade to make a crenelated (like the top of a castle) edge. Anything dull and coarse will work great on drywall. Big triangles, squares like you find on a thinset trowel.
I bought some scraper blades years ago. Haven’t worn them out yet.
dnschmidt
Phoenix, AZ
I use the Japanese style oscillating blades with the sharp teeth like those used on a Japanese saw. They zoom right through the drywall.
ChevyEFI
Phoenix, AZ
I saw that kit sale with 1.5ah battery.
That seems low for M18 batts. I'll have 5 and 8 for backup.
Will the 1.5ah be useful?
rlitman
Long Island
When sharp, those make fantastic wood trim cutting blades. I wouldn’t dull mine on drywall, but I do recycle them.
P
pugglewuggle
TX
1.5 is pretty small for a tool like this that uses a lot of power
dogdog
I thought about welding a sections of all band saw blade to revive the life. Have all the materials including eBay coils of extra wide 1-1/2 width blades. Just gave no time or need. Yet. Well they do say necessarily is mother of inventions. Unfortunately I don’t have the need.
rlitman
Long Island
Years ago, I welded a section of a carbide tipped sawzall demolition blade to one, do make something that wouldn’t dull on my plaster walls. It works great, but now that you can buy them, it’s not worth the effort to make.
sparky 1971
Central Iowa
I just use my worn out blades and I have plenty of those. As soon as a new blade sees drywall, it's useless for anything else. As long as there are teeth, they will cut sheetrock though.
engineer2
Chicago burbs
That's exactly what I did and it works great.
WES51
California
I used a drywall blade and found that it wears out just as fast. I think I hot maybe 20 feet of drywall cutting out of a blade before it dulled.
For this reason, I find using and oscillating tool for drywall less than ideal, unless it is some specific application need (which I have not found yet), where a regular saw would not work.
