SuzukiGS750EZ
- Joined
- Apr 26, 2012
- Messages
- 3,273
It fires the injector because it's ground side switched and completes the circuit?Close:
Remember 4 cylinder engine, so only 1 bank.
All cylinders share a power feed, Orange. The vast majority of things the engine computer controls are ground side switched. Meaning they always have power, ECU supplies ground to turn things on.
That means the other 2 colors are the controls: But look at the pairing, 1 and 4 share a common control wire, as do 2 and 3. On a standard layout 4cylinder engine, what do 1/4 and 2/3 have in common?
They're companion, or sister, cylinders. Meaning when 1 is at TDC compression, 4 is at TDC exhaust. Same for 2 and 3.
Now, this isn't an uncommon setup for ignition systems, it's called waste spark. 1 and 4 are fired at the same time, regardless of which is at TDC compression and which is at TDC exhaust. This allows for "dumber" computers and lower resolution cam/crank inputs. All the ECU needs to know is when the cylinder is at TDC. If it's TDC compression, great, power stroke is created. If it's TDC exhaust, it's a "waste spark".
Thus 1/4 and 2/3 can share an ignition coil each. Instead of 4 individual coils, we have 2 coils, on for cylinders 1/4, and another for 2/3.
__________________________________________________
So, if Orange is the power input, and Green and Purple are switched grounds to control the injectors - What happens when the green wire is provided a ground path?
