FiendFX
Does anyone know where I can get this NEW at cheapest price? Or something similar you can recommend? Thanks
Wow, I can't help you out with a new one....I spent months tracking one down, and I had to buy it used.
Tool topia lists it, but is "currently out of stock" http://www.tooltopia.com/otc-tools-3398.aspx
To clarify, OP is not looking for noid lights. Noid lights test the electrical signal to an injector (or other non PWM DC device). This tool allows the technician to manually trigger a injector without the vehicle PCM in the loop. It is typically used for injector drop testing (monitoring fuel pressure drop on a primed system per injector). Helps to find injectors with poor spray patterns or in the performance market, it helps get a matched set together.
Bought mine from www.usatoolwarehouse.com paid i believe like $30.
