OTC D-10 "screwdriver" - What's it for?
amecks
Jordan, NY
I picked this up today for way less than a buck. It is a screwdriver of a sort. Like its meant to turn a screw that fits over a shaft. As you can see the screwdriver shaft is hollow. Marked OTC D-10, outside diameter about 3/8".
Can anyone tell me what it fits, and on what vehicle it is used?
Thanks
Al
Tostal
The Emerald Isle
Looks like a driver for 'Bezel Nuts'.
Bezel nuts are the internally threaded rings that hold e.g. car radios or switches into dashboards on older cars.
These bezel nuts don't have a hexagon , instead they have 2 small grooves in the outer face, which are used to turn them.
T~
These bezel nuts don't have a hexagon , instead they have 2 small grooves which are used to turn them.
T~
I agree.
Mintgrun
Kingston, Wa.
It would work well on these. This is the back of my car's instrument cluster... with an added ground strap/wire attachment.
I modified a screwdriver tip, since I did not have the proper tool.
Tom
4xdog
Santa Fe, NM
Seems kind of small for the bezel nuts I'm used on on my vintage Triumphs, and the profile seems a little more pronounced. But there are lots of bezels, and that would be my guess too.
Here's the kind used for Lucas dashboard lights on vintage British cars -- 3/4" and 1" diameters. TBH, the nubs on these are smaller than many of us would like.
Firebrick43
West central Indiana
Some guns use the same style of nuts, the cylinder rod retainer on single action revolvers made by ruger. Also 36 to 41 flush nut m1 garands and post lock bar sights like the T105 on the m1/m14/m1a did as well. I have seen some double shot guns of greener crossbolt type design(and belgian clones) use them for the pivot bolts and reinforcing/cross bolts in the stock as well. They would predate automobiles.
ttpete
Dearborn, MI
So for adjusting the dwell on an old window style Delco distributor.
Those used a 1/8" Allen wrench.
The older Delco distributors used a nut like that under the terminal nut. After the wire was disconnected, the nut was loosened to allow the breaker arm to be removed inside. SO had a tool that looked like a screwdriver handle with that type of tool on one end and an 11/32" socket on the other end to remove the outer terminal nut. I still have mine.
JjKk40
New York
Could be an hvac refrigeration tool to adjust valves. I have an old Bonney socket set with different sockets for that and they look just like this driver.
Tostal
The Emerald Isle
I enjoyed the link as well. Interesting to see all the special tools otc provided in 59.
