It's 8F and the well is still overflowing. The ditch Mom made to direct it all out of the yard was a really smart idea as the ground is frozen now and it'd be making a huge mess without it !!
WAAAAAY back on Wednesday evening Dad decided the ground was frozen enough to finish the soybeans that were in the mud.
Munching through them and driving right over the mud !!
While he was doing that I started raking more corn stalks to get baled.
See !!! Ethan is back to bale more. We intend to sell the bales in this field so if you need some hit me up, I've got 150 to sell
While he was baling I started fueling tractors up for the day. Between 3-4 tractors and the combine we'll burn through 225gal of diesel a day. Plus the dryer uses in the neighborhood of 40gal/hr of propane which the gas man keeps full for us.
We parked the combine at a neighbors place overnight so we could plug it in and he's got a scale from the old Avon Feed Mill. We weighed the little green wagon to get a tare weight so we could calibrate the yield monitor on the combine.
It's a really cool old setup !!
Simple and never needs a software update
There was a 3' square metal cover in the floor so I had to lift it up and investigate. I've never been below a scale before and it was pretty neat.
Dad combined some corn and I weighed it and we found out the combine yield monitor was reading 8.8% low. Now we know.
When we haul from this farm we put another smaller wagon behind so we can bring home 800ish bushels at a time to save trips and to be able to stay ahead of the combine.
It's cold and we're alternating green, red, green, red. You'd think we're getting ready for Christmas
The front wagon had a bit of a tilt to it and we looked into it ....
There is a large washer/bushing that is worn out. It prevents the steering deal from wearing into the frame. Parts are ordered and will be here on Monday but until then we'll grease it up often and use it. It'll be fine.
The 886 has a German engine in it so dripping a little oil is normal. If it doesn't slobber a little something is wrong
First load of corn home with the newly repaired wagon. Seems to be holding up great !!
This is what nice looking clean undamaged corn looks like.
This is what hail damaged corn looks like. We left the rest of this and will finish it last and use it for cattle feed as it's not saleable like this. There are too many black kernels and we don't want to take the chance of mixing it in and having a load rejected.
"Ay oh ay oh ay oh ay
And the engine ran like the angels sing
We're harvesting, ay oh ay oh ay oh ay
And we combined on into the night
Ay oh ay oh, ay oh ay oh
And we combined on into the night"
Water is A LOT easier to deal with when it's frozen. We'd be getting stuck all over in this field if the ground wasn't frozen .....
Wow this was an amazing sunset !! Stupid camera doesn't do it justice.
We talked all summer about how it'd be nice to have some lights on the bins to use while unloading and guess what ??? Never followed through for some reason. Argh.
Top bearing is out on the hot auger so we add heavy weight oil and some corn head grease to keep it going for a few more days.
