Outdoor 4 Post
Overhaulin63
Akron, Ohio
Hi Guys, I am located in northern Ohio and was wondering if anyone has experience or issues with having a 4-post lift outdoors? I understand hydraulic hoses, may for most brands, probably do not have UV protection, but I just wanted to hear your experience and concerns with this idea.
As always thanks for your feedback!
Love this site!
Lou's Garage
Anderson, SC
Sorry I can't pass along any recent experience but during the 50's my father had an outdoor 4 post lift at his first shop. This was located in the lower Hudson Valley in New York state so the climate is similar. I was little, so I don't remember much but I do know it was the only lift so it was used every day weather permitting. The only complaint I remember my father voicing was the relief that in his new shop (see avatar) the lift was indoors so they would not have to work in the weather. So it can be done.
Since those lifts are full of cables, pulleys, and locking mechanisms; I would think that you'd need to keep everything constantly lubricated. Even if they are not exposed directly to the weather, humidity alone could cause things to get stuck and operate erratically.
Lou Manglass
66Caprice
Stanwood, Washington
We have them all over here in Washington state. Most are at the exhaust shops. If you take good care of it I don't think it would be a problem. But the cold weather will slow down the operation of it.
finn
The UP, God's country
When I was looking at four post lifts four or five years ago, I remember the manufacturers saying for indoor use only.
The motors on the power packs aren’t weatherproof, for one, and the cables are likely not stainless steel. Most pulleys probably don’t have zerks, so there’s no way to keep water out of the bushings.
Unless you find one specifically designed for outdoor use, it’s a bad idea.
dave*99
Coastal NJ
There are parking lifts designed for outdoor use. I don't know if they are convenient for service work.
I have a friend that has a 4 post Bend Pak lift outdoors in NJ for about 10 years now. He keeps a bucket over the hydraulic unit.
I wouldn't do it but it seems to be holding up.
Junkman
Northeastern CT
I had my BendPak outside all summer a few years ago, and there was no problem. I did have a problem getting a 10' wide 4-post lift in through a 10' door opening. When my BendPak lift was manufactured, they were centering the bottom plate in the middle of the 12" square bottom plate. The posts built after mine are all welded, so the outside of the post is at the edge of the bottom plate, which would have made mine a lot better to get through the door opening. At my old shop, I had an ancient 4-post cable lift outside, and it always worked well. I don't remember the brand, but it was manufactured in the 1950s. There is a local shop that has one like the one that I had (1950s model) that has been outside since 1980, from what I remember, and he is still using it, weather permitting.
I do like the idea of putting a carport covering over it with some panels on the sides and rear. It will keep the weather off of it, but you still need to ensure the cables are protected from condensation. My friend who lives in Apple Valley, California, has his outside, however, he lives in the high desert, so rain isn't much of a factor. The rubber hoses can be protected by plastic hose wrap if the hoses are a concern.
Hobby_Man22
tx
You go out into the county, you'll sometimes see a guy with a lift behind a fence usually. I guess they don't really have any zoning outside city limits if I understand correctly. There's a guy about 1500ft away from me who has a diesel repair shop and lives on the property. For about a year I just thought it was the neighbor reving the **** out of his truck late at night when he told me it was his neighbor. Never really understood what free revving a diesel to redline accomplishes.
