ToddW
Until I get my 'big wire project' completed I'd like to be able to use my welder, and now that it's winter running the 100' extension off the dryer out the door isn't too friendly for keeping the house warm, and critters out
By putting in an outdoor outlet I can get by with my 25' extension cord which is MUCH EASIER to handle than the 100'.
Plan to run this:
https://www.amazon.com/dp/B00M3H6494/?tag=atomicindus08-20
or
http://www.homedepot.com/p/Eaton-50...Temporary-RV-Power-Outlet-Box-CHU1S/100565603
But, just want to make sure my cords that fit this:
https://www.amazon.com/dp/B00004YUNT/?tag=atomicindus08-20
Will also fit the above, obviously not using the neutral. Extension cord is for single device, no 120v outlet.
Complete Plan:
- 50A Receptacle (Attached to 4"x4" support on outer edge of deck. I will also add a wood 'cover' to keep snow/rain 100% off this outlet)
- 6GA For the 2 hot legs
- 8GA Ground Wire
- 2" SCH 80 PVC Conduit
Will be attached to side of house as well as under deck from house main breaker box to 50AMP outdoor rated outlet/box.
Plan to run this:
or
Complete Plan:
- 8GA Ground Wire
