Outdoor flood light recommendation
radio2000
Looking for a good led outdoor flood light, preferably smart, that I can turn on or have it motion sensing. Any ideas?
Kevin Essiambre
Ottawa, Ontario, Canada
The RAB FL series (FL1, FL2, FL3, and FL4) are fantastic lights, but they're just that... a light. You'll need a motion sensor or photocell or a switch of some kind to control the light.
I've installed quite a few of them. The latest was an FL4 mounted 20' off the ground for my mechanic. Lights up his yard and the neighbors field quite nicely.
Sent from my new phone. Autocorrect may have changed stuff.
R
radio2000
Decided to go with two Ring floodlight cams. Big fan so far. Only “complaint” is the delay when u open the app
ambenz
NW Chicago Suburbs
I have this under the corner eave of my garage pointing at the driveway and alley, I love this flood for the Dualux technology... it features two-level lighting; at dusk, the light automatically turns on to an adjustable low ambient light, keep the neighbors from complaining a light is on all night and it is too bright.... and then it brightens to 100 percent when it detects motion for added security.
Patriot Lighting® Dualux White LED Dual Head Motion Sensor Outdoor Security Flood Light
Model Number: E6922W Menards® SKU: 3569240
Features
Includes mounting hardware and an instruction manual for easy installation
Has adjustable sensitivity to customize your needs; detection ranges from 10' to 70' with detection zone 180°
Features adjustable shutoff delay to customize your needs and timing ranges from 5 seconds to 3 minutes
Features 2-level lighting; at dusk, the light turns on to an ambient light, then brightens to 100% when it detects motion
No tools needed for adjustment; tool-less feature for ease of adjusting light heads to specific areas you'd like covered
Life expectancy of 30,000 hours
Dual mounts option: light can be mounted on eave or wall
Has multiple lighting features: light can operate as motion sensor, dusk to dawn, or manual override with a switch
This LED light has a CRI of 80, a color temperature of 5000K (Daylight), and is 2000 lumens
This thing is "BRIGHT!"
