Outdoor garage lights control
unvago
This has been covered numerous times but I will try to explain what I need.
I have 4 exterior garage lights and would like to add one remote exterior motion sensor to control all four lights.I presently have a control that installs in the switch and a remote battery sensor that is mounted outside to activate the switch. It is not reliable.
I do not want to replace the lights with individually controlled lights.
I would like to again add one remote sensor that would control all the lights but is reliable.
Git
S Cal
This might work for you or at least point you in the right direction. It is designed to work with a Z wave controller, but I *think* it may work without one - but you probably should call and ask. It least it gives you an idea what to search for, or you may want to get involved with Z Wave Home Automation
https://shop.homeseer.com/products/z-wave-floodlight-sensor?_pos=1&_sid=e103b8023&_ss=r
