happyj
Stupid use question. Adding a small load center Siemens w0204ml1060. 60amp. I have a 50 4 wire circuit coming from the main panel and will add a couple of 20amp legs to feed my wife's pond. I read the 4 wire docs and that makes sense but I run into (my ignorance) problems with the ground. See picture, there is a bus for neutral but only a screw for ground. Is there some way to add a bus to that so I can have multiple grounds? Thanks in advance
