Outdoor tool usage/storage ideas?
remagenman
Hey folks, this is another " I have too many tools!" question:
On the back yard I have my shed for woodworking, it faces the back of the garage. In the outside of the garage wall I have a table with a grinder, welder, planer, orbital sander, belt sander, stuff that wont fit into the shed.
I currently have a brown tarp covering all this when not in use and pull the tarp up when I need to use a tool. It's effective but ugly. It has surprisingly kept the tools dry for a few seasons now.
Question: I want to build a non-permanent storage enclosure to make this more presentable. I was thinking a slight overhang roofed box of some sort that does not attach to the garage wall? Something that resembles a woodshed maybe? How can I cover the front without using a tarp?
Thanks.
Bessy
Ontario, Canada
Without a photo of what you're currently working with, nor a budget, it's tough to recommend something. How big an area are you looking to enclose? I know lumber is dear right now, price wise, but if you're into wood working would you not be better to frame up a quick lean-to style shed? You could either build a single aisle in with a door on one end, or double doors along line side so you step right into the box with your bench along the back wall?
rayra
Escaped from Los Angeles
Shallow tall cabinet / shed with folding doors, doors also storage, so you open the doors to have a complete tool wall of your outside stuff. Maybe add a fold-down bench.
Hephaestus29
Indianapolis
I have a LARGE Vise mounted on a pedestal just outside the garage at the corner of the garage. I keep it covered with
a plastic 55 gallon barrel that I cut one end off of. It’s something I thought about doing a long time ago but only did it a couple years ago. I wish I had done it sooner because it’s great for larger pieces I need to work on and if I’m grinding the dust is outside. The barrel keeps it covered, but I would spray some rust inhibitor on it.
