Streetbu
So I built a lean to off the back of my garage and want to add a single light, and outlet, and an outdoor outlet mounted on the steel siding. The switch and "indoor" outlet will be next to the current opening so they need to be weatherproof, as of course does the actual outdoor outlet. Is it ok to use the gray pvc conduit for all of this? I just ordered an outdoor 2 gang switch and outlet plate. Everyone had them separate but not together. Now if I can find a 2 gang PVC box with three 1/2" holes. That's proving harder than expected. Here's a pic of the lean to. The switch and outlet will be mounted on the left side of the actual garage, light overhead, and the outdoor outlet on the back side facing the back lawn which is to the right in this pic.
