Outlet covers with stacked stone
Ralphxj
NE Ohio
Have a wall with stacked stone and need outlet covers for 2 outlets. Any suggestions for covers that can sit level? Guessing it will need to be some that can cut to match the couture of the stone? Or do I need to cut the stone? 20220131_205710.jpg
The Cobbler
I did a backsplash with similar product for a customer & what I did was cut back the stone and used all the same thickness at the plates . ran the stone vertically along the sides of the plates
it's a bit of work
LSUfj
Maybe try building up a flat surface over the stone, roughly the size of the cover plate, with a grout that blends well with the stone, install plate over that.
wssix99
Chicago, IL
For that particular situation, I would cut the tile back to the exact size of a shallow Wiremold box:
Install the Wiremold box over the outlet box, then install the outlet and cover on the Wiremold box, and then caulk or grout the edges. (This would have been easier before the tile went down but can be done with some patience and maybe a Dremel tool to clean the corners up.)
The Wiremold backing plate should bolt right up to the electrical box you currently have installed. All you need to do is cut the tile back to a flush surface so it buts up against the surface mount box.
