Outside Stair ?
dldude
Hello, Maybe someone has some input on this. The 2x12 stair treads on the outside stair of my building are cupped and hold water. The bad part is the stairs face Northeast and never really get any sun. The building was built in 2015 and I have treated the stairs several times. My wife wants to drill some holes to allow for the water to weep. I don't think this is a good idea since it will open up the wood core and speed up rot. In hindsight maybe the treads should have been 2 2x6 instead of 2 x12. Any input would be appreciated.
LiketoFix
OHIO
2-2x6's would definitely help! She's correct in the hole drilling, but you can Drill several small holes and then re seal including inside the holes with A q-tip and place some sand on the sealer for grit to extend the life of the existing treads to save a few bucks!!! I wouldn't drill too small or too big of holes either. 3/8 th's size holes might be what the Dr. ordered. Steps need to be people friendly young and old! IMO!
LtF
mike93lx
Richmond, VA
Definitely do not drill drainage holes.
I'd remove the 2x12's, tape the stringers with joist tape and install dual 2x6. Most say install with the end grain frowning so that they cup with the center *******, but that's debated as much as what brand of truck is best, even though it is objectively Ford.
LiketoFix
OHIO
Different Strokes!
It's easy to spend or even try to save you money!
A lot of good comments and opinions. Sounds to me you better check with your wife first! LOL!
LtF
billconner
Thousand Islands NYS
Trex is a nice idea but I suspect you'd have to add a few stringers - 9" on center is what Trex site says.
Wondered if with the right jig, you could cut slots with maybe 2 blades on a circular saw - wide enough kerf so it doesn't clog up with dirt quickly. Lot of fuss and time, very low material cost.
RaisedByWolves
SE PA.
Anyone who says to install with the grain “smiling” probably eats hot dogs with ketchup and drives a ridgeline.
