Hello everyone.
I am going to be moving into my first house very soon and I am happy to say that I found a house with a 3 car garage and a little bit of extra work space.
I typically do a lot of work in my garage and I would like to make things easier if I can.
The one area I am really interested in is lifting heavy things. Be it an engine, a crate, building materials, whatever, I always end up with a trailer full of something I just plain cant pick up.
I have seen several posts on this board where people have overhead beams with trolleys mounted. Can I add this my existing structure? What kind of mounting would I use?
The garage has wooden 2x4 trusses perpendicular to the intended beam mounting. My first thought was to use bent steel brackets to go over the truss and bolt on each side to the beam. I could do this every 16", but in the end I dont want to end up pulling the roof down with the weight of the beam and whatever I lift. I figured I could double up the truss beams if needed.
Would it be better to try and engineer some sort of self supporting frame and bolt it to the concrete rather than to hang it from the ceiling? Obviously I would like to hang it if possible to save the floor space when not in use.
How is everyone else mounting their beams?
