Hello;
I am in process of designing an overhead steel structure that will be fabricated inside my boathouse. I will source the steel locally & have an iron worker come fab & do the welding.
My question comes in regards to making sure the proper 'uprights' (one at each corner) with appropriate gussets for raking, etc, and the side to side upper I-beams are sized correctly. The local marine contractors are not structural engineers, nor am I, so another set of eyes would be great, looking online my setup would consists of a dual point load on the upper beams?
For uprights, I would like to be able to fit these within the 2x4 stud cavity walls (3.5" actual) if possible, so I can finish the walls. Should the uprights be pipe or square tube?
Attached are some pictures for reference, Max weight would be a 25K boat (most of weight in rear due to engine(s) and fuel..
Any help would be greatly appreciated.
Thanks
Thanks
