Overhead furnace vent pipe sizing question
martincc
Hello, I just picked up a used Olsen KAS100 overhead has heater for my detached garage. I have a gas fitter coming to pull the gas permit and install the gas line. I plan to do electrical myself with a city inspection and also install the roof vent myself. My question is regarding the roof vent. The outlet on the furnace is 6", do I need to run a 6" vent or can I go to a 4"? 4 seems to be more available here in Calgary AB. Also, had to find info on codes here. The exhaust for the unit is straigt up, can I just run the pipe straight up from the unit, through the roof, or does it need a bend for some reason? It will be 2 ft away from anything at its final point, low sloping roof. Anyone have any links to manuals on this unit, hard a hard time finding anything. thanks! If anyone is from Calgary, where is the best place to find vent pipe?
csp
Franktown, CO
You can step up in sizes, but never down. If it's 6" coming out of the heater it needs to stay 6" or larger all the way out.
martincc
any idea where I cna buy this? Seems impossible to find in Calgary.. home depot does not sell it. Is a stright up design ok, no bends are necessary?
