Overhead garage storage?
Gizzygone
The Racor, and fleximounts ceiling storage lifts seem to be discontinued: but they seem like a great solution for getting strollers/toys up and out of the way without needed a ladder to get them back.
Anybody know or an alternative, or DIY solution that’s similar, without breaking the bank?
Dmcastino
Indianapolis
So you are looking for one big shelf that you can raise and lower?
I imagine that with some creativity, you could make something similar to the products you listed using parts from a unistrut catalog and either a hand crank or small electric winch.
G
Gizzygone
Yes, a platform I can raise and lower.
What I’m running into is not finding a solution that would get me right to the ceiling or close the walls.
The harken hoist seems like the easiest to DIY, but the design requires a long run of cables which isn’t feasible.
GarageSmart has a neat solution, but it costs a pretty penny…. And I’m not keen on app-based tech.
It’s too bad the racor and fleximount aren’t being made: they check a lot of boxes for me!
u2slow
BC
I built shelves in place and use a ladder. The trick is to find/build a simple ladder just for this.
G
Gizzygone
Certainly is the easier way to go about it: my thought with a rack that moves is my wife will be more likely to use it.
Plus it’s a touch safer to bring the rack to the bulky items I want to store, versus hauling it up a stepladder.
mike93lx
Richmond, VA
I use a couple of these for canoes in my garage. Maybe something like this could work?
I wouldnt haul anything up with it that can't handle being a little out of level though as it uses two separate ropes.
Kayak Hoist Set – Overhead Pulley System with 125 lb Capacity for Kayaks, Canoes, Bikes, or Ladder Storage by Rad Sportz (2 Pack) https://www.amazon.com/dp/B06XGMSDCP/?tag=atomicindus08-20
Copymutt
Colorado
A fold down ladder works for me. At one point I needed to hoist a welding project into my truck. A couple 2x6s nailed to the attic studs and stuck out thru a vent opening worked well. Used a winch. So my thought is consider an exterior “barn” hay loft door approach. Preserves interior space. Increases the size of items easily put in the attic. Be sure of your engineered loading.
wmihl
Sun Prairie, WI
After buying my first Racor lift I knew I would need one for my kayaks. So I went to look for one and like you said, out of stock, unavailable and nowhere to be found. I did find one through Facebook Marketplace. If you have the time just keep an eye out on sites like this, or maybe Craigslist.....if that even still exists. LOL
Good Luck.
rayra
Escaped from Los Angeles
you could make one readily enough with a platform, eyebolts, some pulleys and steel cable and a small winch. But if safety is your chief concern I wouldn't do it.
