I'm trying to understand how thin and proper way to pour a slab ontop of an old one?
The older part of my outbuilding is about 24" wide x 32 deep -- it was built as a garage. Typical block foundation 2x walls. When they built it back in the 60's they just graded the floor with a slope to the front a bit over 4" down -- poured concrete slab. It's sort of flat .. lots of small cracks now. It's solid. Have no idea how thick or if it has any stones under it -- I'm sure no VB.
6 or 7 years ago I got a price from a local guy to rip it out -- dig down and do a proper base -- foam insulation/ VB .... PEX in the new slab. He was around 15k.
My plan now is to have a wood floor
Currently the slab is at the top of the foundation in the back and it drops the 4+ inches over the 32 feet.
I would like lay down a VB. Over-pour the old slab -- make a flat surface. That way I can lay 2x4 on the flats w/ glue to the slab -- some power nails to hold in place. Foam between the sleepers -- floor on top. Possibly a simple radiant.
If I over pour the thin area 1" is that enough -- or do we just feather to the old slab. I don't know if it's worth trying to fill in the deep area with anything .. or just pour the concrete thick
It does not have to look pretty -- it does need to be flat
