Override for light timer - check my logic
Falcon67
Merkel, TX
I have a electro-mechanical light timer that is working perfectly well controlling the driveway lights. Got to thinking it would be good to have a manual override for turning the lights on outside the timer settings. Thinking a three way switch would do it, see attached. The only "downside" I see is that the second switch terminal would be hot during timer ON time. See attached
chops101
S. FL
I take it you're opposed to replacing the switch with an electronic timer based on geo data with an over ride switch built in?
I'm slowly replacing my mechanical outside timers as the motors wear out.
F
Falcon67
Merkel, TX
The timer is in the attic, so the internal on/off is not readily accessible. The original switch is down in the laundry room on an insulated "exterior" wall between that room and the garage. Existing wire, stapled, etc. The switch controlled the driveway lights and exterior floods - I put the driveway on a timer and left the floods on the switch. After a quick fix, now the missus wants a dim flood or LED to shine across the bedroom window exterior - that light is on the exterior floods. I may end up with both - off timer on/off switch surface mount in the garage and a separate run from the timer to her little flood outside the bedroom. Your typical one hour fix 'em up turned complicated.
My timer is old-old and still working, if it quits ever I would source a more modern unit. I just put some nice low power LED down lights in for the driveway and would like to see them when we come home after dark. I plan to add some soffit down lights in the front if I find some that I like and are dimmable.
This whole thing was a zero cost deal, using stuff laying around.
