MFortie
2"x6"x26' span Doug Fir with 24" spacing?
The ceiling joists in the little garage on the property we bought is built as above. The previous yo-yo (owner) had drywalled the ceiling, added insulation (they had some folks living in it) and had some sheet goods stored on the joists.
They also put a partial wall down the center -- probably to help support the weight! When I removed the wall studs (that's all they were), the ceiling kind bounced if I pushed on it with my hand!
I pulled the drywall, insulation & removed the sheet goods and it's quite a bit better, but still moves 'a bit'.
The garage is built with 2"x6" on 16" rafters (stick built, no trusses) with a 2"x10" ridge board. Skinny little sheathing (3/8" maybe) and asphalt 3-tab shingles.
I'm thinking about adding ceiling joists to make it 16" spacing and maybe sistering another 2"x6" on each side of the rafters just for peace of mind...
Thoughts?
Thanks,
Mark
Thoughts?
Thanks,
Mark
