I'm just under roof with my new garage, and have picked back up the research for a heating option, but man oh man! - the more I read and research the more confused I get. Now I remember why I shelved the heater research several months ago ...
I was looking for the easy button, but that doesn't seem to exist, so I have some stupid questions that hopefully the collective can help me with to point me in the right direction.
My garage specs are:
- 24'x36' detached garage with hip roof and 2.5' overhang. 3 separate doors
- Inside ceiling height is 9'6" and the eaves are ~8" lower than the ceiling.
- Natural gas line plumbed in, and located in Pittsburgh.
- The underside of the roof deck and walls will have closed cell spray foam insulation.
I don't expect to keep the garage at 70°, but just want to keep it at or above 40-45° so nothing freezes, and turn up the heat while I'm working in it.
Stupid questions;
1. I was hoping to keep the rafters (truss) open for storage, and wasn't planning to finish with drywall. Is a drywall ceiling required in order to use a vented type heater (Hot Dawg, Big Mazz, Reznor, etc.) for a detach garage?
2. I prefer not to have to vent through the roof, but I can't figure out how to side vent with 2.5' overhangs and a hip roof (no gable end). Does the side vent need to run 3' below the eave if it's going to extend 6" past it? What is that minimum vertical distance from the eave if extending 6" beyond? If still 3' then side venting isn't an option because the vent pipe would need to exit at ~5' height (which is a problem both inside and outside)
3. What about a ventless radiant type heater (like Dyna-glo) - I haven't seen a lot of posts/information here about that as an option? They're comparatively inexpensive and simple to install, but can they be controlled via thermostat? There has to be a drawback that I'm missing.
Thanks in advance for any input and advice. Looking forward to any discussion to help me get educated and simplify what seems to be overwhelmingly confusing right now.
Stupid questions;
