Fireball027
I am new to using Oxy Acetylene torches. I bought a set of "B" tanks and the "Industrial Oxy-Acetylene Welding kit" item # 92496 from Harbor Freight.
I am having a problem however... With the hoses connected I have no flow of acetylene past the "check valve" on the end of the torch handle. Oxygen flows fine through the check valve. With the check valve removed from between the hose and the handle Acetylene flows and I can light it.
I did buy a set of flashback arrestors and have them installed between the torches and the hose.
My question is should I buy another set of check valves or is it safe to use without them and just have the flashback arrestors installed?
Thanks for the help.
