zkdiesel
Looking into getting one. Any one better than other? Need a cutter/pin burner
Next question will it burn pins out like a torch? Will a siezed pin melt away from the edge of the bore like you would a torch due to the different metals/temps or will I score the bore easier?
I’m good enough with a torch I can commonly melt a nut off a bolt and reuse the bolt... will I be that good boring a 8” long 2” pin out of a bore?
Thanks
www.airgas.com
Thanks
Airgas - -
Sure Cut Heavy Duty System - compatibule with 1/4, 3/8, and 1/2 OD Sure Cut rods. JRSC2024S-HD includes a sampling of 1/4, 3/8, and 1/2 OD rods, does not include regulator. The Oxylance Sure Cut system will cut virtually any metal, both ferrous and non-ferrous, and is faster than conventional...
