Strouty
Nice build, tilting it to the side makes me think of a spindle sander. Have you used the disc sander portion much? I have a couple of belt sanders, I am looking for a nice disc sander or a combo one.
Excellent post fella's.
As usual, I am a day late and dollar short, but for interest here it is anyway.
I too, have a MultiTool, had it for nearly 30 years and have had no trouble with it. Unfortunately in the last few years PA let the manufacturing out to China and the Chinese tooling is somewhat suspect.
I have seen quite a few crook ones on display in the shops here in Oz, but hopefully problems were weeded out before they hit your side of the pond.
It must be said the PA is fulfilling any warranty obligations pretty well and any defects are being remedied quickly. Watch for, run out on the driver wheel and tracking problems related to the right angle bracket not being a true right angle.
There's someone here in Australia making a platen for them which requires a 48" belt. It made a huge difference to the Multitool which I already use 5 times a week on average - easily the most used power tool in my workshop.
Here's a video about the platen and the bloke who makes it.
http://www.australianbladeforums.com/vb4/84-engineering/21983-multitool-upgrade-kit-video.html
No affiliation with him, just love the product.
Ozwelder
What do you do with that striking knife you made?
Sent from my MotoG3 using Tapatalk
Oh, OK thanks, as is "striking" a lineIt's used for scribing a line in wood instead of using pencil. It's sharp so it goes right up against a straight edge and it cuts the fibers of the wood too. You could use a utility knife too, but that would just be boring.![]()
While I was repainting this grinder (the day after starting this thread), I did something that will make the installation mounting bracket easier. Finding the right length bolts to hold the bracket to the motor housing was a bit tedious. I would end up with bolts that would fit in 2 out of 3 holes. I couldn't just add washers because then the bolts heads would run into the shaft collar. I ended grinding them to lengths that worked. But, since I had the grinder apart, I tapped the holes all the way through the casting. They are 1/4-20 and we're only partially threaded on my grinder. I would NOT do this unless you have the grinder apart. I don't think it would be a good idea to have chips from the tap floating around inside the motor. It does make assembly easier and is worth doing if you are going to have your grinder apart anyway.
McBrownie:Taking your advise and prepping mine for this belt sander kit while it is apart. Did you just run the tap until it bottomed out as my tapped holes are not drilled all the way into the casting?
I am over thinking this as drilling these out from the inside would easily solve the issue and allow for a full through tap. Here's a shot of the inside:
While it's still apart, please advise the DIAMETER of the rotor, and the THICKNESS of the stator lamination stack. I'd like to compare it to some other grinders I'm toying with.
Made a couple measurements, but want to be sure they are for the right parts. The rotor seems to be straight forward as that is the black area on the shaft, correct? Measured 2.62 in.
Stator lamination as in the large block that surrounds the windings? Measured 1.75 in.
Let me know if you need anything else as it will be apart for a week or so while I clean up the other parts.
McB - Now that the grinder is back together, I am in the process of confirming the spacer width for the Multi-tool that I picked up Thanksgiving week and found an interesting difference between our grinders. The distance from the side cover mounting surface and the shaft shoulder on your 3/4HP was 1-5/8 compared to 1-3/8 inches on mine. Add in the variable of our shaft collar widths with .51 vs .40 on yours, which explains why your 7/8 spacer width looked a bit wide.
Now I am doing some ciphering to get mine spec'd out, but ~ .5 inch looks to be the magic number and correlates to the combined delta between the shaft collars (.11) and exposed 17mm shaft length (.25). Now I need to spring for a couple beers and hit up a machinist friend to get one cranked out.
Almost done as one of the last remaining tasks is to enlarge the countersink holes on the disc plate as the 10-24 screws have larger heads than the originals and are not sitting flush (countersink on order). Also think the GFCI issue was resolved as the grinder fires up now without issue. I still need to get the permanent spacer made, but that is just a matter of finding some time to meet up with a machinist friend.
And surprisingly enough, it is very stable on the original CM stand.
McB: Thanks for the great write up as it made this project very straight forward![]()
Just read this entire thread and learned a lot. Thanks McBrownie and others for the scoop on setting up this shop tool. I already have a 6x48 JET belt sander but those can have their limits for accessibility. My old Craftsman 1 hp grinder looks like the one in post #108. I'm going for the 2x48.
