I have a Bendpak 9000 lb lift that I do not plan on bolting down as I have the caster kit with it so it can be moved around I used it in my previous garage not bolted down and it worked fine that way, so now I am in the process now of coating my new garage floor and was thinking about using something like this since the size is good without having to cut them :
4 Pieces RV Jack Blocks Rubber Pads Trailer Jack Camper Accessories RV Stabilizer Jack Pads Jack Stand Pads Trailer Leveling Pads for Keeping Jack Blocks from Slipping Sinking, 12 x 12 x 0.2 Inch
or some kind of RV jack pads under the 4 posts bases , has anybody here had any luck with using these or does anybody have any other reccomendations of what to use since the lift won't be anchored so it can be moved around ? Thanks
