I want to build some upper wall cabinets similar to Jack Olsens. Do you guys suggest plywood or mdf?
Jack,
The finish on your cabinets look very durable. What process and type of paint did you use?
Ed
That pretty much sums it up....
Here is one of the kitchen cabinets I built using plywood and solid maple...
And one of the upper cabinets I built in the garage using gray melamine.
The melamine is over twice as heavy....but needs no paint or finishing....
It is very rigid....but you have to attach it properly....shelves will sag if they are long enough...but I solve that by attaching 16g strip of SS across the front and back edges....in the back I make it 3" tall....no sag.
You can see more of my cabinets in the garage build link in my sig.
Wanna come do my kitchen cabinets?That pretty much sums it up....
I personally despise particle boards of any type, but they are OK as long as you don't get them wet.
For clients I usually use birch veneer for the boxes, and poplar for the faces, if I am painting them, or cherry/cherry , mahogany/mahogany, etc. .
Someone just posted some beautiful pictures of some upper cabinets he just made, showing the cut diagrams, the pieces, and the finished product. It was posted as part of his garage build, but it was a perfect example of how to make a cabinet. I put adjustable shelves in mine, set up for L clips that fit in 1/4'' holes. I make a predrilled story board for the holes, and use it for a drilling jig for all the cabinets.
I'm lazy and cheap. I've accepted that about myself.
That said, I try to work around my shortcomings. So the cabinets in my garage are nice down where they're getting a lot of use (the steel level), and merely functional for the stuff that's in longer-term storage (the soffit level).
But back to the cheap and lazy part. I used whatever I had on hand, pretty much, when I built them. So the upper cabinets are framed with 2x4 and 1x2s, the sliding doors are hardboard-type MDF, and the doors slide in 2x4s that I've grooved with a table saw. The shelves inside (when there are shelves) are either plywood or OSB, depending on what I had that was the right size.
Most of this has worked great. Some of it has come back to bite me in the ****. The wood cabinets above the inch-thick-steel bench have shifted with the buidling, so now my to-do list includes going up and re-configuring the slides for them. The stupid thing I did when I made most of the sliding doors was to only cut the grooves deep enough to hold the doors in place. What I should have done was to make the upper grooves 2x as deep as the lower ones so that I could lift the sliding doors up in order to remove them. I finally got this right on the doors I made for above the sink area. Live and learn.
Here's the latest set I did. I've gotten so that I can bang these out pretty quickly. But that's happened just as I reached the end of the road for my garage storage space.
And here is a picture of the last set of sliding guides. As you can see, each is just a 2x4 with grooves cut into it. The deeper ones go on top, so the door can be lifted up to be removed or installed. It's so simple, but I didn't think of it at all on the first two batches of doors I made.
