Paint booth lighting question
newlywv
West Virginia
I am needing to replace the lights in my paint booth with explosion proof lights suitable for paint booth use.
My question is do I need to replace the entire light fixture? Or is there a housing that will hold regular flourescent lights to make them explosion proof?
Where is the best place and prices to get what I need?
Any input is greatly appreciated.
Thanks,
Rich
Gooch
Petersberg, IA
Thanks,
Rich
Your best bet is going to be getting ahold of a sales rep from Crouse-Hinds or Kilark. Do you know the exact classification of the space? Class I Div. I or Div II? Group A, B, C, or D?
I havn't seen anything other than replacing the entire light fixture, but doesn't mean there isn't a retrofit kinda deal out there.
jdieter
Northern Indiana
Explosion proof fixture will get pricey real quick. Is it possible to install plexiglass windows and use standard fixtures outside the booth.
Docholiday
I agree. If u have a claim there will be no problems. Inspection documented is very important. Then u have peace of mind. Also u will have correct controls for fire an fan, lights shut down.
PRH44
Indiana
Explosion proof fixtures are very salty. Most paint booths I have been involved have openings in the booth filled with glass. The fixtures are on the outside shinning through the glass. This is usually done with a standard fixture out side of the class 1 division 1 area.
Wiring inside and around the booth openings have special consideration and it isn't the cheapest.
Docholiday
That is correct! I think it is 8' from an opening have to exp. proof. At least that's what I recall on doing the last one. And if any opening like a door is opened or a fire while painting the fan an air for paint is shut down. Everything is a nice little package if u buy complete.
Norcal
Standard fixtures behind wired glass are the most common way, as hazardous location fixtures expensive, from what I heard somewhere around $1500 ea., A AFC brand spray booth I wired came w/ a couple fixtures classified for the conditions that were installed at the entrance door & the double doors at the other end, would have loved to had the money it cost to run the heater. :D 1.1 million BTU natural gas heater & a 30,000 BTU pilot light....
