I need a little feedback here.
Trying to have a paint booth inside a clean, want to somewhat keep it that way, garage. I have to keep the boat in the 3rd bay, the lift has to go in the center, #1 bay is my work bay and the tractor bay is my engine shop so the best place for the booth is the third bay. I plan on making it out of 1 1/2" PVC pipe wrapped with clear poly. I'll install a door that is basically one big filter top to bottom for air intake. I'll build two filter boxes that I can connect flex duct to and snake out under bay #2 door and connect to a belt driven fan outside. This will be run out away from the garage and concrete pad.
The booth out side door I can hinge so I can still pull the boat in/out. For a longer project I can park the boat under the lift but it runs the full length of the garage. Pain in the **** to walk around and a very tight fit. First bay is impossible to back it in.
This design should allow me to keep it up for awhile and I can store the fan and duct in the attic when not in use. I'll have side lights on the wall side outside the poly and tri-pod lights between the booth and lift. The light fixtures overhead are at 10' and I figure a 8-9' height inside the booth.
Being made of PVC and poly I can dismantle it and store it. I'll try and attach my drawings. Some of my concerns are static in the poly and keeping the soon to be tiled floor clean.
What do you guys think? Suggestions for improvements are welcome.
not sure how bad I've have to be to be considered that but...
