MayerMR
Hey fellas,
I'm working on a project (restoring a vise that has been re-welded/repaired in the past) whereby I want to hide some imperfections in the item. It's a tool so I don't want to spend hours and hours refining the surface to make it perfect, but I would like it to look decent enough.
I ground down the ugly welds a little bit, then mixed up some JB Weld to use as a filler to further hide the bulging imperfections. I've sanded that down now and it does look much much better. I then put a filler primer down last night to prevent any rusting and to see how it brought out the imperfections - and there are some.
That said, I'd like to paint this vise a "verde green" color, but I'd also like to hide some of the imperfections but using a textured paint, like a hammered-type paint.
Long story short, the color I'd like isn't available in the hammered-type paints and I wanted to know if used a Hammered White or Hammered Silver to get the textured effect, then let it cure for a couple of weeks before going back over it with a green paint if I'd likely lose that hammered effect?
Thanks for your input fellas!
JB Weld filler sanded down - looks pretty decent, but not perfect.
The primer really highlights some of the filler areas - I can do some more sanding on the dynamic jaw area, but that was the area with the most welds post crack, so it's always going to bulge a little.
