Paint PVC pipes to make them interesting?
dwljpl
I have a pair of 4" PVC pipes in the corner of my garage. One for the dryer and one for waste water. Has anyone painted PVC or somehow used exposed pipes as a canvas rather than try to hide them? I was thinking painting them bright red or bright green and adding nuclear symbols on them to make them more interesting than plain old white PVC.
gregtwojeeps
Ky
Just scuff them with some 220 grit or a green scratch pad and paint them with latex paint.
D
dwljpl
That's the plan, I was just curious if anyone had done anything more interesting or had pictures. :D
countryroad82
Kentucky
I've seen them painted like water towers and trees for model railroads. Then I've seen them painted to look like steel for an industrial look. You're only limited to your imagination.
gregtwojeeps
Ky
O.K. I see. Once you do a internet search and find the stencils you like for your art, or maybe go big guns and buy an air brush set and learn to do air brushing ....there is a lot you can do for art work. Now my concern would be before the art work is done, is using a PVC pipe for a dryer vent. Good luck on your project :thumbup:
Norcal
While I would not use PVC for a dryer vent, I would not lose any sleep over it's use, the temperature of the exhaust air from the dryer is well under the maximum temperature the pipe can withstand. Just for the record, galvy sheet metal duct is preferred by me.
coljar
Belpre, Ohio
If they're PVC and they're in the garage, the only proper thing to do is paint them blue and stencil "AIR" on them.:lol:
Richard Cranium
central Washington
I have seen retail stores use pvc pipe to hide the chains that hold signs off the ceiling. They had just sanded the lettering off so that they looked like white pipes. But I think painting them is a good ideal. I also have some in my train layout that is painted.
gregtwojeeps
Ky
To expand some more on your post above... anytime I read where someone has mentioned something in their project that could be a hazard... and for sure one that can become a FIRE hazard, I feel I have the responsibility of mentioning it. Just as you do over on the L/E forum...
As to not derail the OP's topic though, while listing the negatives of using PVC pipe on dryer ducts here... it would probably be best for the OP to just do an internet search and see for himself about why PVC should not be used for dryer venting, if he chooses to do so..
Plenty of info on this topic out on the WEB including the DIY Chatroom forum and You tube videos. Including the building codes standards listed in IRC M1502 -4 which does not include PVC as a suitable dryer duct. He just needs to type in his browser, " PVC pipe for dryer vent" JMO
NUTTSGT
Northern Central Ohio
How about some nonpotable water signs for waste water ?
The reason for not using PVC for the dryer duct is that dryer fires happen. While it may be ok for normal average dryer temps, if there is a dryer fire, the PVC will not contain it. That's why most will recommend metal duct for the dryer.
rkevins
Central Arkansas
I have painted them with spray paint, I think I used regular krylon, painted the dryer vent for house and in a office I worked at I painted a 4" piece od DWV and made a fake pole for computer wire to run through
tab2
Boston
Lacquer thinner will take off the lettering. When I worked on custom homes we would do that so the mechanical rooms looked cleaner.
I think erodz painted some piping to make it look industrial but that man is an artist
SARG
Northeast
Fusion spray paint for plastic comes in some wild colors.
Proper prep per instructions with ammonia solution before painting and the paint lasts a long time.
I've used it on plastic gutters and even changed the color on an entire vinyl sided 12 x 16 shed.
D
dwljpl
Dryer vent was installed as part of the house build from new. Electric dryer, and I stay on top of scrubbing out the vent with a wire dryer vent brush. Can't believe they'd use this and not flag it during inspection. :sad:
dfiler2
NW Minnesota
Seems to me PVC would be better than that plastic with the spring in it that I've seen installed many times, though maybe that is not approved, I always assumed it was.
Norcal
Just because something passed inspection does not mean that everything is OK, inspectors are human & they do miss things, some are stupid too.:D If the building dept had separate inspectors for building,electrical,mechanical, plumbing, a inspection is likely to be more through, then when a combination inspector who wears all those hats does the inspections.
dreamingmuscle
Tryon Oklahoma
Ditto. Also PVC generates a lot of static electricity when used as dryer vent. Greatly increasng the rate of lent build up in the system.
shortykorte
Tallahassee, Fl
Please post pictures of what you end up doing to your two pipes.
Side note: in N. Fla, PVC for dryer is used on most if not all homes.
MikeF2316
Thornhill, ON
Or paint them all glossy white like you see in those factories and have some stickers made for them indicating they're carrying something exotic.
egnorant
East Texas
I would tend towards silly stuff. "Non-tactical air only" , "Do Not Open Until 2075", "This side up" (pointing down of course!).
Maybe put a Russian space program logo and a scary looking warning in Russian or Vent access on sub-basement 3 only!
Bruce
CJ7VFR
Central New Jersey
Fusion spray paint for plastic...
I used a few short pieces of PVC pipe, that fit inside my patio umbrella stands to raise the umbrella's up a few inches so I don't hit my head on the umbrella's, and I used the Fusion Gloss Black spray paint on the PVC and it worked out great.
I scuffed the surface of the PVC pipe with a Scotchbrite pad, wiped it off, and then painted them.
It has lasted over 2 years now and still looks great and matches the black umbrella stands perfectly. No one even notices that it's PVC pipe in there!
Jim
countryroad82
Kentucky
Rayra I like how ou think! I've often threatened to make one of the dull boring walls in my office at work into an ecto containment unit.
