Paint Question
danc333
Southern New Jersey
I just purchased an old Power King drill press. I want to give it a new coat of paint. My question is to you guys that have restored things like vises and machinist tools. What type of paint do you use, and what type of prep is required. I will try to post pictures,but right now the file size too big. Thanks in advance.
Kevin54
MEMBER EMERITUS
Urbana, Ohio
What type of spray equipment do you have access to if any? Prep is the key to any paint job. Degrease and clean first. Sand with 400-600 grit paper. For the little nooks and crannys that you cannot sand by hand try using red Scotch-Brite pads. If you do not have spray equipment you can use rattle cans. If you have a compressor, pick up a HF spray gun or a small cupped gun at a place like TSC. Best bet would be to use an automotive type primer and paint, but you can get good results with rattle can paint. After you prime, sand the primer using 600 grit either wet or dry. Then use a good cleaner to pre-clean before painting. Again, if you have a paint shop around, get a wax and grease remover to clean. You can also use alcohol in a pinch. Pick up a couple of tack cloths and wipe down right before spraying the paint using caution to use the tack cloth lightly and not press it down as it will leave a residue.
LoneGunman
The Gunshine state
Plain old rustoleum will work nice but you must be real careful until it hardens, a few weeks or so. I only spray large flat pieces, in my opinion you get a much better finish using a high quality brush, if the paint is thinned properly and you use a good brush you will not get brush marks. If you do a google search on machinery restoration or machinery painting you'll find some in depth posts on Practical Machinist and other machinist websites that deal with painting with a brush.
Kevin gave excellent prep advice
