Paint Removal from Parts
Vintage Veloce
San Diego
I just took the very old flagpole mount off of our 100 year old house. Lots of paint layers on this, some certainly lead based. The screws rusted off in the wood!
So... whats the easiest way to strip the paint off of this? Is there something I can soak it in? I don't have easy access to a sand/bead blaster.
V
Vintage Veloce
San Diego
It's magnetic, likely cast iron.
Boiling water! Way too easy, I would never have guessed.
Dad would have soaked it gasoline in the 1950s... I think I'll try the water first.
PoorUB
Fargo, ND
If you have Boraxo a tablespoon in the water will help too. Pretty sure you don't need to boil the water, just get it hot.
rayra
Escaped from Los Angeles
Jasco makes a gelled paint stripper that's very effective. But you'll instantly know if you splatter any on your bare skin.
Boiling!? Excellent. Never would have occurred to me.
FredWanaker
NorCal
I cleaned some hinges in boiling water and baking soda once. Worked really well to soften the paint on them. Worked better than leaving another set in a can of MEK and Acetone. Both methods worked.
Jayman17
Seattle, Wa
Another non toxic way is an overnight soak in Simple Green. Factory paint on old power tool parts comes right off this way.
Jay
Yankee2bbq
Mountain Home, Arkansas
I’ll add my 2 cents.
I use oven cleaner to strip and clean various parts. Buy a couple cans from Dollar General or from Wal-Marts. Place that flag pole mount in a coffee can and spray the heck out of it with oven cleaner. Do it OUTSIDE. Soak it down good. Let it sit over night. Spray clean with garden hose and wire brush. Wear gloves when handling it.
ZRX61
Solar Blight Valley, SoCal
A pot of water is free. For cleaning a single part, I don't know why people are suggesting more expensive and complicated methods.
If a teaspoon of laundry detergent is going to cause someone to miss a car payment & cause confusion, they may want to reevaluate their finances & ask their college to refund their tuition ;)
danfromsyr
Cicero, NY
my take is I'd go the chemical free methods 1st.
last thing any of us need is more oven cleaner and solvents mucking about if not necessary.
but I'd also consider tossing it in the woodstove for a spell ;-)
we boiled the antique locksets in our house..
was nice to see the Bennington Potters clay door knob come out from under half dozen coats of paint.
polished that knob up real nice and it's a treat to put ones hand on.
an original fixture to this 200yr old house made by hand from clay out of the ground in Vermont.
isb cornbinder
I have been using a product called gunwash. Gunwash is used in the automotive paint trade to clean spray guns. This is a strong lacquer product that can be very rough on skin. Use with caution. Gunwash is very flammable. I have often filtered the gunwash and used it many more times.
I bought a paint mixer. It had up to 2.5cm of dried paint inside the cabinet. I opened an area on the dried paint and poured some gunwash in and let the cabinet sit for an hour. the paint lifted off, easily.
MoonRise
Note that using lye or oven cleaner (which is usually a spray can of lye) or Simple Green or ANYTHING alkaline (and lye is really-REALLY-really alkaline :lol: ) on something made of aluminum WILL etch (with short term exposure) or dissolve the aluminum object.
To remove paint, I'll usually use ...
paint remover. :lol2:
And although I do (now) have access to a media blaster, on an old probably lead-paint coated object I'd use chemical removers to remove the paint first and then maybe clean the metal with the media blaster if needed.
Cast iron sitting in water, with various corrosives in it (baking soda, soap, whatever) probably would not be my first choice as I don't like turning a painted cast iron object into a rusty formerly cast iron object. Personal choice. :beer:
V
Vintage Veloce
San Diego
Well, I tried a short dunk in boiling water (30-60 min) and the outer layers came off... but the older, likely lead paint didn't budge. My wife forbid me from using one of her pans on the stove for a longer boil... I'll have to buy a cheap pan at goodwill and put it on the grill. Or... I do have an old can of zip-strip...
Yankee2bbq
Do the zip-strip. Or oven cleaner. Don’t be scared.
Shiftless
East Bay SFO
Reading about others’ success with plain water, I will try that on my next non greasy vise stripping job. Needless to say, soaking in hot Simple Green for a few hours gets hardened up old grease out of difficult to access places in old vises. That’s why I like the SG soak method.
But as others have already said, some laundry detergent in water might be almost as good.
Stripping that flag pole mount is really straight forward.
txvwnut
Bedford, Texas
For old grease or oil residue you'll most likely need a detergent of some sort. For just straight paint a sak in boiling water works wonders. If the paint is really thick it may take a couple of sessions but avoiding chemicals is never a bad thing.
