Paint sheen for garage walls/ceilings
oriffx
Chester County, PA
Any recommendations for type of sheen for the walls and ceilings??
I'm getting black/red Racedeck tiles for garage but need to figure out the paint. Not just color but sheen.
People seem to prefer the shiny over flat. That is gloss/semi-gloss over matte.
seagravedriver
Puyallup
I did white "Gloss" a few years ago, and never really liked it. I thought that it would be brighter and look good. It just was never right and highlighted imperfections. In this house, I used white "satin", and it is great. It covers a lot more imperfections of my beginner level drywalling. Another thing that I can highly recommend with a fluorescent light with more "blue" in it. When I open the garage, it makes me think that I left the garage door open on a bright day. At my local hardware store, there are 4 types/colors of fluorescent tubes. I like the blueish much better than the yellowish/brown.
7th Kahuna
Los Angeles, CA
Historically, flat paints were impossible to clean and in some cases would just wash off if you tried to scrub them. They also did a poor job of sealing the surface so if you rubbed grease on the wall, for example, it could bleed through and make repainting difficult. Today's paints are better, provided you are using a quality paint. Personally I would use a satin enamel in most areas, and semi-gloss in wet or particularly dirty areas.
Check out this link:
Behr Paint Sheens
I'm not necessarily recommending Behr paints but it gives you an idea of their thoughts on the sheens.
For the ceiling you could use something with a lower sheen.
O
oriffx
Chester County, PA
Good point about the light. I didn't consider that. I suppose a high gloss paint may look goofy with fluorescent lighting. I see your point.
seagravedriver
Puyallup
My walls have never gotten all that dirty, or they do evenly,or I have so much **** I don't notice! It depends on what you are doing, so you may need to keep the ability to clean them on your mind. I love the lights. I will try to post a pic.
workhurts
VA
I think I did satin. Wouldn't go any more shiny unless you really plan on throwing liquids at the walls. I've contemplated doing something more durable on the bottom 3rd but haven't.
c4cruiser
Lacey WA
I used some cheap semi-gloss white I got from the local Wally World. When I finished my 3-car garage, I used a white primer followed by two coats of the semi-gloss white. The interior lighting is 5 sets of double 4' T8 bulbs with 5000K brightness Phillips bulbs.
I also painted the lower half of the walls with a light tan color and a 5" red border between the two colors. That helped to break up the white but didn't change the overall brightness. I also used an epoxy floor paint in a light tan.
Lassen Forge
I like that - the stripe and offwhite on the bottom do break it up, and looks a lot better than one solid color!
We did an interior flat white on one (the rental with the cool "studfinder" top edge moulding) and it picked up and showed dirt like crazy. Couldn't get it clean for love nor money without scrubbing the paint off. Ouch! Right before we moved, we repainted it with an exterior semi-gloss (sometimes, you have that kind of landlord you want to do a favor for, in a good way, ya know), and right away you could tell the difference - much nicer end effect. Whoever got the place after us won't have to deal with the issues we did. (The LL was so impressed he reimbursed us the cost of the paint)
About Exterior VS Interior - the Exterior will (usually) take abuse, getting wet and/or nasty and then being cleaned way better than interior. Also quality makes a huge difference in paint - you can get the el-cheapo $9.99 a gallon special, but you get what you pay for there. I was told (by a painter) to ask some pro paint companies what they use, and go one grade better.
JimVonBaden
Northern Virginia
I went semi-gloss and do not regret it at all!
cdestuck
Altoona, Pa
Semi gloss is great. Gloss is just too shiney. And the semi is a lot more washable than eggshell or satin. I used SW classic 200 20 years ago and still looks like new.
dubber
Canada's Capital
Although i'm definitely not an expert i would agree with those that mentioned exterior paint. As for sheen i would say the less shiny the better. I went with a semi-gloss on an accent wall in my garage and up close i'm really not happy with. Too shiny and shows imperfections.
saradanyal
Dubai
Garage ceiling paints should be durable enough to not peel or crack and cover any old stains. If your ceiling has many imperfections, you'll want to stick to a flat paint sheen. The best interior paint always work best for ceilings.
Viper98912
GA
It depends on what you're planning to look at on the walls.
Flat paint, especially in lighter colors (white base) is the best for hiding imperfections. Most of the time, this means poor mud jobs.
Eggshell and semi-gloss paints accentuate mudding flaws in your walls, but are much more resistant to dirt/grease stains and are easier to wipe off. What mudding flaws you see all depends on your lighting setup - where your lights are relative to where you're going to be standing and how it's going to be reflecting off your walls.
I was personally in the eggshell camp for many years. But I have corner lighting in my garage that reflects down the entire length of the wall. This shows ALL of the mudding flaws when walking in through the door. From here is when I decided that flat was the way I needed to go. [Ironically, I had this same issue in a previous home as well, there was a large wall in the living room that you could see down from the kitchen, and when I installed some wall shelves on the opposing wall with backlighting, you could suddenly see the reflectivity of the eggshell down the entire length of that long wavy living room wall from the kitchen; the framers didn't understand the concept of having the crown of the 2x4's all face the same way...].
But unfortunately, yes, flat paint is very sensitive to the lightest dirt/grease stains, even from something as simple from what you think are nearly-clean-gloves; you barely brush a wall (with the back of your glove!) and you see a resulting huge grease mark. Frustrating.
So in the end, in my opinion, it depends on what kinds of flaws you want to see. Mudding/drywall flaws, or future grease flaws.
WisJim
Menomonie, WI
I went with a good quality (Benjamin Moore) semigloss on the walls and am happy with it. Ceiling has two coats of white primer and that's it for the ceiling.
frankd
Long Island, NY
Exterior paint should not be used indoors because of certain additives which off gas for a long time. (Google it). With that being said, lots of people use exterior paint in garages with no issue. I don't think exterior paint is necessarily more durable though.
As for sheen, I went with a matte. Sherwin williams also makes a "washable flat". As Kahuna said, flat paint had come a long way and is much more durable than it once was.
Flat/matte is better IMO because imperfections in the drywall are less noticable. Also, you can touch up flat/matte finishes without an issue. If you use anything with a sheen, touch ups will be noticeable unless you paint the whole wall to the corner.
My personal preference is flat on the ceiling and matte walls...but I did all matte in my garage to save time
phred
NC
Super high gloss oil. Cleans easy, reflects light well, covers better than latex. I need all the light I can get so everything is pure white walls ceilings and floors. Cabinets and doors are dove gray or natural.
rmmiller
Kennewick, WA
This guy has some great points in favor of flat but I don't think he uses garages the same way some here do. I imagine a good sealer primer would help with liquid penetrating the drywall.
