Craftsman86
I have been in the process of restoring a couple older tool boxes, and have tried everything from the single stage paint clear coat combo to using rattle can and everything in between. My question Is it necessary to use a clear coat over a rattle can paint job? If so what do I stand to gain by applying it? I have had great luck with the sunrise red rustoleum and the paint center associate advised that the paint is heavily mixed with a gloss finish in the cans as well as the quart cans that is why it is so much cheaper (and takes more coats to cover) than does a high end PPG paint in the same color. Furthering their point they indicated how much clear or filler as he called it goes into the $50 quart compared to the $180 quart of the same color paint. If there is an abundance of clear mixed in the formula would you need to apply it after the material drys or is there going to be a minimal gain from doing do?
On my current box I am restoring I have found that after several weeks of the finish drying a finger nail run across it will leave marks in the finish. If this can be avoided by adding a couple more coats of clear coat I will happily apply it, but if it is not going to be a benefit I don't see the time and money spent as a constructive use of my time.
What do you guys think?
