Painting an old garage
the5
Well just rented this garage for my race cars and want to paint the walls.
Was wondering the best way to go about this, was thinking a sprayer because of all the weird angles.
thanks
Eric!
ronnyg801
If you have access to an airless it will definitely make things easy if you are just looking to paint everything. If you need to rent one you may reconsider, I am not sure the going rate.
It is a fair bit more clean up than just rollers and brushes IMO.
Rolling and brushing really won't be too hard though.
59'trump
The prep time may take a little bit to mask off or paper over things you don't want overspray on but I love the use of spray. It's easy and it covers well. True, clean up can be more tedious but the time and ease may be worth the trouble.
Cyberbear
California
Based on the photos, it appears that power washing the walls and floor will be needed, to remove as much as possible, any soot, dirt or oil based contamination. Then rent an airless spray rig and shoot the walls to clean things up as you may need.
nadogail
Coronado, CA
IMHO, this job is a perfect fit for an airless. We did one three years ago just like this.
1st we Cleared out all the left behind trash. 2nd We blew out the webs and dust with an LP air hose. 3rd We taped plastic sheeting to mask the floor, 4th We sprayed everything with Kilz 2.
Then we pulled up the plastic and enjoyed lunch.
After 4 years the tannic acid in the redwood sheathing is beginning to stain through.
Git
S Cal
If your going to be there a while and want to do the job right - I would say spray and then backroll it
(Backrolling will improve the adhesion by actually forcing the paint into the surface and it will help even out your coats)
