Painting Cabinets, Need Help.
dthor68
Greer, South Carolina
I have some oak cabinets that I want to paint white. I cleaned everything well with crud cutter, then sanded well with 220. I primed with Insl-x Stix, 2 to 3 coats. Top 2 coats is Benjamin Moore Advance. This all went fine and dandy with the cabinets. The doors did not do so well. Primer looked great. However, when I applied the top coat brown staining started coming through. The only thing I did different was I brush painted the cabinets and sprayed the doors with Graco X-5.
So, I am guessing that I am going to have to strip it all down and start again, what would be best way to go about this?
Thanks,
logan09
Upper Michigan
As was said, you're getting tannin bleed through most likely. I'd use a shellac based primer, or shellac in general.
yeldogt
The insl is a bonding stain blocking primer .. good stuff. But -- it's a water based .... do they rate it for painting Oak?
Still seems odd --- was the insl fully dry? Do you think your brushed was a thicker coat?
Do you have any advanced primer? That's what I always use.
I don't like universal primers .
Gunfixr
behind the house
Shellac based primer, covers anything. I used zinsser B-I-N.
Covers anything, I mean anything.
I covered walls stained with nicotine tar, as in running down the walls, shiny.
Then painted right over it, couldn't even tell.
Label said it would cover wax and grease, they may be right.
joey1320
NE Ohio
Because I had no clue what "Shellac" was --
"Shellac (/ʃəˈlæk/)[1] is a resin secreted by the female lac bug on trees in the forests of India and Thailand. It is processed and sold as dry flakes and dissolved in alcohol to make liquid shellac, which is used as a brush-on colorant, food glaze and wood finish."
Human ingenuity is amazing.
yeldogt
Make sure you do two coats if you cover with any of the pigmented shellac
Git
S Cal
As others have mentioned - BIN primer. No one like sanding, but nothing sands like lacquer/BIN. It literally turns to a 'powder' and won't gum up your sandpaper.
Lay down a couple coats of BIN and sand it to get a near perfect surface and it will make your final finish coats look great
