I had a new sectional detached garage built a couple of years ago and decided to board the inside out.
I used kingspan insulation on the roof, insulation sheeting on the insides of the metal doors and fitted moisture resistant chipboard on the walls.
This looked great but not there are signs of moisture (from before i started using a de-humidifier) and marks on the walls so i'm wanting to paint them white.
Reading on the net there seems to be no specific answer what type of paint to use on moisture resistant chipboard so i'm stuck?
Options are
to try a wood primer them acrylic paint and hope it look good?
or - go over chipboard with plywood sheets before painting them?
I don't want to have to paint several coats to get a nice finish so should i use the chipboard as i'm guessing it'll be easier to paint?
Pic of garage as it is now (22ft x x10ft)
Options are
