My reply is assuming the vinyl is rigid and not "soft" rolled on where it flexes...
Think of painting vinyl being the same as trying to get paint to stick to plastic, NOT easy to do as it takes a special primer to bond to it and the primer is the key, in being able to get the top coat paint to stick. .
I bought a primer for some pvc "Fypon" I had ripped in to 16" x 96" flat panels for a exterior porch beam at work that I was installing, to replace rotted plywood. When I asked the Sherwin Williams paint rep to give me a primer that WOULD STICK TO PLASTIC OUTSIDE, he sold me his special primer that would stick to plastic outside. ....
I bought his recommended primer and scuffed the pvc panels with some 240 grit for extra bite, cleaned, primed, and then top coated them with SW exterior latex A100 gloss. ....
That was two years ago and the plastic "wood" panels are mounted on a porch support beam outside year round. They get hit with the full morning UV rays which make the Fypon panels expand and contract, endure temps ranging from - 5 deg. F. to 98 deg. F. annually, and the paint on them is still attached and looking good. So your vinyl being inside out of the weather, would be a breeze for the paint I used. Good luck. jmo.
