Pallet Racking--Value?
Adrien
Taft, CA
I'd like to use pallet racking as shelving in my new shop to store my decoys and other clutter. This guy has had this posting going for awhile here locally, and I'm not sure if it's a good deal or not since nobody has picked it up yet. I'm not well versed in pallet racking so I'm wondering if what he has available is a good deal or not.
http://bakersfield.craigslist.org/tls/2417930236.html
Thanks,
Adrien
-Brent-
Utah
That's not too bad. Where I got mine from the uprights were $35 and beams were $10 each. Wood can range, I used 5/8" and some scrap 2x4s and 2x12s. So, if I were to buy that much from the guy I used, it would have been right around $500.
SpyderMike
I recently sold mine which were about 9' tall with three sets of shelf braces at 10' wide and with wire shelves for $150 a section to a company that resells them.
mtwaterguy
Most pallet racking is pretty deep. Looks like the sellers is 4'. In a small shop that might be a problem.
A
Adrien
Taft, CA
I'm planning on running it down one of my end walls where I should have about 4' of space between the bay door and the wall. This bay will house my 5th Wheel so on the other side of it I'm planning on just doing the shelving. I'm going to continue shopping around, and if this isn't available when I'm ready to buy I'm sure something else will come up. Costco sells some 2' deep pallet rack style shelving for around $155 a section, but that would add up pretty quick spanning 40' of wall space.
Adrien
Cryptic1911
Willimantic, CT
I bought 12 uprights 3' deep, 40? crossbeams 7' long, and 30 3'x3' wire decking for $450. The uprights were 18ft, so I used a portable bandsaw and cut them all to around 11', and kept the 6' pieces for parts and pieces. Might make some small carts or something.
Here's a shot of it all packed in the old garage (new was still under construction). I layed the uprights down and stacked all the decking and crossbeams on top
MartyO
N.W. Georgia
I have 20 feet of 12 foot high pallet racking in my shop on the back wall. It chews up space but I store a ton of heavy stuff on it.
Well worth the investment.
Carl B
Clearwater, Florida USA
Adrien:
Might I suggest that you do a sketch of your wall - and lay out what you think would be an ideal setup. Depending on what you plan to store, or what you need shelf space for. Measure the actual interior depth that you have to work with - you don't want stuff sticking out past your door openings.
Then do a lot of research and shopping. There are many suppliers of used Bulk Storage or Package Racking - - most of the commercial duty stuff is pretty strong. I'd suggest you shop them to see what kind of deals they offer - let them know that you want "complete" units with all cross supports, shelf decking {wood or wire} and at least 4 shelves per unit. Then go look at them to see if they are in good shape - not all dented and rusted.
No question that the Package Racking / Bulk Storage Racking that I bought for my garage years ago, was one of the best things I've done for myself. My units were 6' tall, 8' wide and 4' deep. I couldn't reach selves higher than 8' anyway, and I wanted shelves that a single sheet of plywood would cover.
If you are storing shorter items - you might need 5 or 6 shelves in a 6' high unit etc. All depends on what you want to store.
BTW - Pallet Racks are technically different than Bulk Storage or Package Racking. If your calling around unless you have a fork lift and are actually storing stuff on Pallets - you most likely will want to specify Package Racking or Bulk Storage Racks. Always commercial duty stuff...
good luck,
Carl B.
Brad54
That's not a bad price... you're getting a LOT of storage for that money.
Getting it with the wood is a big help, too, because wood prices have gone up in recent years. If you had to buy wood for the shelves, you'll be adding a couple hundred bucks more.
You MIGHT find that quantity cheaper, somewhere, but it'll take a lot of looking. You'll definitely find it more expensive at a lot of places.
I've got one 10-foot long, 4 wide, 12-foot tall rack along the back wall of my 32x40 shop, and I cut a second down to 4 feet tall, 8 feet long with two shelves, and put it in the short loft above my office. It's fantastic to have. I've got cylinder heads, cast iron exhaust manifolds, transmissions, flywheels, etc. on it. Couldn't be without it.
-Brad
svtrichie
Troutman NC
I paid 280 for mine. 10ft uprights, 12ft beams for two shelves and the decking. Thought it was a good deal.
sorry about the pic, its behind the wagon.
JSBriggs
Auburn CA
Thats a good deal, especially if its local. The price fluctuates withe the price of steel, but that is double the amount of rack I bough for about the same price.
-Jeff
Full Size 66
Wa.
If that falls through there are usually one or two local industrial salvage places that carry the pallet racking. I know of one guy here who has the two foot wide and four foot wide. I had never seen the two foot, it looks the same as the four foot just smaller...
Carl B
Adrien:
A few more things to think about - as you shop for storage shelves.
Bulk Storage Racks/Package Racks
Section Length:
8' - pretty good all round length for garages - not much stuff will be longer than 8'
10' - takes 1 and a 1/4 length of plywood to cover
12' - takes 1 and a 1/2 length of plywood to cover
NOTE - Section Length - if the shelf supports are 8' long - then the total section length might be 3 to 4 inches longer - depending upon how wide the Uprights are. Measure all sections total length carefully to assure that they well fit in the area you have. 5 each 8' sections might require more that 40' to fit in.
Section Depth
2' great for storing smaller stuff that you want to find easily
3' a good compromise between 2' and 4' for general automotive garage use
4' great for storing wide stuff like hoods, doors - but too much stuff can get hidden in the rear if you are storing smaller stuff. {or you have a lot of wasted space in the back of the shelves - that's hard to reach on the higher shelves}
Section Height:
6' - great for 8' ceilings - hard to reach anything on shelves higher than 6' anyway
10' - if you have 12' ceilings and stuff you rarely need to see and/or limited on total length
12' - great if you have 14' ceilings and are limited on total length
With a 40' wall - I'd like to have 5 eight foot sections, each with at least 3 shelves - for smaller stuff at least 4 shelves depending on the depth. For "decoys" you may find that 2' depth with more shelves per section is ideal.
The deeper the shelves, the higher the space between them needs to be. If you have shelves 4 ft. deep and some are 5' to 6' off the floor - you'll never be able to reach the back of the shelves unless you have at least 24" between them. {and you stand on a step stool or ladder to reach the back of the shelves}.
With the stuff that is advertised - you'd be able to put 4 ten foot sections on your 40' wall {maybe!!} - but you would only have 2 shelves in each section. That would leave you with 2 twelve foot sections with 2 shelves each left over. Then the question becomes - where do you find more 10' braces, that match the connections your uprights, if or when you need more shelves?
Draw your ideal setup out - then pay what it takes to get what you really need or will want in the future. You'll most likely be using this stuff for years and years to come - so spend what is needed.
FWIW,
Carl B.
A
Adrien
Taft, CA
Great advice everybody, I appreciate it. I feel like I have a pretty good idea on what to look for instead of just buying whatever is available at the time. I'm in no rush so I'll keep looking.
Thanks again!
Adrien
Cryptic1911
Willimantic, CT
You also want to pay attention to what brand racking you get as alot of them have different clip styles and they aren't compatible. There are many different brands, ridg-u-rak, unarco, teardrop, interlake, sturdi-bilt, etc. Interlake and teardrop seem to be the most common from what I've seen. Just make sure you find out what you have so that you can buy more crossbeams in the future if you need as they aren't universal fit. Most of them just clip together, some have to be bolted, and some, like sturdi-bilt you need to have these clips that go through the uprights, and the crossbeams rest on those. I don't really care for that style as you have a shitload of clips you can lose
Carl B
Cryptic911 has posted some really important and useful information. Easy to see why it is important to get everything you need with whatever "package" you buy used. A few extra cross beams can be easily stored for future need - so better to have a few too many, than too few.
I'm keeping a copy of the pictures too...
thanks,
Carl B.
Charles (in GA)
50 mi south of Atlanta
I have Interlake brand tear drop style uprights (3 of them), 14 ft high, and 40" deep total, with 24 ea, 8 ft lightweight open bottom beams. The beams have shallow "notches" on the upper inside for the plywood/wire grid/boards to fit into.
On some shelves, I used 2x6's like Home Depot does on their pallet rack/shelving but with the shallow notches, the boards stick above the edge of the beams. On one shelf, I used scrap ends of 5/4 deck boards that were long enough to allow me to cut them down to 36" to fit into the beam notches, they are nearly flush with the top of the beams, on the rest, I carried home pallets that full 55 gal barrels of chemicals come on, and I cut the heavy rough cut boards off the top of the pallets, they too are about 5/4 and worked real well. Plywood is not heavy enough and will bow down unless it has cross supports.
The shelves are 2 ft apart, and the bottom one is far enough off the floor to allow me to get a broom under it to clean. I use the 10 ft rollingwarehouse steps to access the upper shelves (to the right in the pic) I just roll it back and forth in front of the shelves.
Underneath the second shelf, I added some cross braces of wood and use this area to slide 10 ft to 20 ft sections of PVC pipe, angle iron, etc into for storage.
I ended up putting them in front of my sidewall skylights, but the skylights didn't work out as well as I planned anyhow.
I paid about $400 several years ago for this, a little high but I needed them.
Charles
dougmac
I paid around $250.00 for 12' tall x 3' deep x 12' wide with four shelves. It is a steal when you look at other types of shelving. I used OSB with 2x6 stringers for the decking.
Carl B
dougmac
Looking briefly on Google..for aprox. pricing new.
Cross Beams:
96" Beam/5030 lb capacity = $49.50
120" = 56.45 each
144" - $79.03 each
Uprights
8' = $90.00 to $96.00 each
10' = $106.00
144 = $169.00 = 12'
192=$192.00 = 16'
240=$247.00 = 20'
The Uprights are $169.00 each x2 =
The Cross Beams are $79.03 each x8 = $632.24
$970.24 worth of Pallet Racking for $250.00 is a great DEAL, and they look like new.
FWIW,
Carl B.
Carl B
....snipped...
Charles
A little high??? Are you kidding me?
$1425.09 worth of Pallet Racking for $400.00 is a great DEAL
New aprox. pricing
The Uprights are $$79.03 each x3 = 237.09
The Cross Beams are $49.50 each x 24 = $1188.00
FWIW,
Carl B.
Ramblur
Central FLA
I bought new for above my benches from http://www.globalindustrial.com/
for around $500-600 as I recall. Later on I bought a bunch of the black ones
(seem to be the same ones Lowes sells) for $100 at a Crane Cams liquidation
auction. There definitely are deals to be had out there. All mine are 2 feet deep
and thats plenty.
edglimited
Hey guys, a big howdy from Oztralia. Just a few pointers you may want to consider, if you do buy extra cross beams, dont stack them in the corner of your garage, cause in the end they will fall and land on your feet or slide out and land somewhere, normally on your car. Also the ends will bend and lose rigidity and the welds will suffer. The best place for them is on the rack frames, they make excellent front and rear gaurds to stop heavy things from rolling and falling off shelves, and stop sticky fingered little kids from lifting heavy things and dropping them on themselves causing injury.
As for your frames these can be adjusted to any width you want, so if wall space is a problem or a doorway will interfere with the rack then simply adjust the frame to suit. You will need to make or get new 1 x bottom and 1 x top brace to suit per frame, as for the diagonal bracing, simply move one end of the bracing up a couple of holes. Or if you want your frames to be wider, then move one end down a few holes.
Cheers Drew
Charles (in GA)
New aprox. pricing
FWIW,
Carl B.
These are the lightweight beams, note the thickness of the beam is much less than most, and the bottom is open, they have a 1200 lb per shelf rating. They were used, bought from a place that specializes in used racking and conveyers, etc.
Charles
dougmac
dougmac
Cross Beams:
120" = 56.45 each
144" - $79.03 each
Uprights
10' = $106.00
144 = $169.00 = 12'
192=$192.00 = 16'
240=$247.00 = 20'
FWIW,
Carl B.
It seemed like a good deal. You see them advertised in the Seattle area Craig's List all of the time for about this price or slightly more.
-Brent-
Utah
Benches :thumbup: My main bench is based on a pallet rack. I also have a 4' one that I use on a temporary basis. I can assemble it and knock it down in minutes.
Sorry for joining back in a little late but I thought I'd add what I did with my "trimmed-off" pieces.
It's a wheel/tire rack for my early Ford rims and project roller wheels. I used the leftover upright pieces and narrowed them using 1.5" square tubing (1/8" wall). The cross beams were shortened from 100" to 72". I added feet for casters, paint, etc. I'm pretty pleased.
The racks next to this rolling rack are soon to be replaced with some pallet racking I bought for $50 that'll be narrowed to 24" (from 42") and shortened from 16 ft to 8, giving me 4 uprights, enough for 32' of racking. For now I'm just going to go about 12 to 16' and store the extra uprights.
dittle fart around
Vancouver, Washington, USA
My retail site has 24" deep 72" high pallet racking with 3 shelves for $279. These are new units with a 3000 lb rating per shelf. The price includes shipping. Sourced locally retail would be about $225. per unit. Used is definitely the way to go.
sostahoe
I see you are local Reno area. I am looking at trying the idea of pallet rack shelving in my workshop. do you have more info ? these links are dead.
feel free to call or we can do a post to inform the forums again.
Scott
775-77two-6775
But you want pallet racking? These guy's have pallet racking.
http://reno.craigslist.org/bfs/2412003768.html
Could call these guys for pricing, they ship anywhere in US
http://reno.craigslist.org/bfs/2398283642.html
Upon further review youre not to far from reno, this might be a good option, actually.[/QUOTE]
kwb
PNW
Wire decking if you can swing it is a good thing - light makes it through, less surface for dust to accumulate up where you cant sweep as easy.
Wood is my big complaint of the 40' I have along one wall in my shop.
I am a huge fan of palletizing my stuff to store.
Don Hendrix
Huntsville, AL
I bought 3 bays of 10-ft high by 44-in wide by 110-in long for my shop. These will be configured into a single bay and a double bay with 3 levels. Can 6-in steel casters be mounted on these to move them around as needed? Stored materials will not be any heavier than the rack and lumber itself. Will the weight be too much to handle for mobility and safety from tipping?
goodspeed
I have one lightweight one 2.5ish feet deep, 7 feet long, and 10 feet high with two shelves. It was 70 dollars when my local sears went out of business.
Also bought four 6' x 4' x 5' tall sections with two shelves a piece for a total of 250 dollars. I plan on using them as work tables with my machinist boxes behind them. For the price, it's hard to argue with them.
usa
Pallet racking is a great cost effective way to gain excellent storage.
Also used pallet racking is purchased by resellers at scrap metal prices.
So bear that in mind when purchasing it.
Also as has been pointed out...each pallet rack system has its own special end connections..choose one carefully...you will be married to it.
darkk
Willimantic, Ct.
We bought used racking in decent condition on CL. 36" deep, 18ft high, 84 ft long with wire gates all for $450. Just have to look around. Most places that sell new also have a ton of used stuff for sale. You can buy the lighter duty stuff very reasonable. Lighter duty racking is still like 2000lb per shelf...
lovsteel
Hi, the post on bakersfield is invalid now.
Pallet racking is mostly used in warehouse for storage purpose only.
If you are not loading heavy articles, we do not suggest pallet racking as the price is high.
For family use racks, a long span shelving rack would be of good effect with cheap price.
