My next project after my meter swap is completed is to replace our existing interior 200 amp panel with a new 200 amp outdoor panel. The existing panel is from 1981 and is a gte / zinsco panel. The reason to move outside is because the area the panel is located is a closed off guest suite. I plan to install the outdoor panel so that I can run conduit from the bottom back of the outdoor panel through the wall and connect to the bottom of the old panel. The left side of the old panel will right behind the left side back of the outdoor panel, perpendicular. The new panel has a 2” knockout at the bottom back or a 2 1/2 if I use the center or bottom left side location. I will use the existing panel as a junction box to extend the circuits to the new panel. I haven’t found a similar setup to mine online, but I’ve seen conflicting info on what’s acceptable regarding wire type, fastening, and de rating on some other inside to outside scenarios. Conduit length between panels is less than 24”, all the existing circuits in the old panel come in through cable clamps, and I would be extending them through that single 2” or 2 1/2” ******.
Circuits to extend are
(1) 100 amp sub panel feed
(1) 30 amp dryer circuit
(14) 20 amp
(6) 15 amp
I’ve checked the conduit fill and all those wires in a 2” is a little less than 35% and in 2 1/2 less than 25% and if it were considered a ****** it could go higher than a conduit.
Can I run individual thwn wires all through the same entry?
Would the wires need to be secured at the old or new panel as they enter?
Is there a better way to get the circuits to the outdoor panel?
Can I extend the grounds using the existing ground bars?
It seemed straight forward at first until I started researching and it seems electricians have different interpretations of what is code compliant in different parts of similar scenarios.
All will be inspected by the city electrical inspector.
After the meter move, the feeder will be coming in the bottom right or bottom right side of the new outdoor panel if that makes a difference.
Thanks for any help.
(14) 20 amp
(6) 15 amp
