Basically I am trying to determine which spot can accept tandem breaker (if any).
It's a GE panel that use "Q" breakers.. where they are 1/2", 1", or 2".. for example to make a quad, you use a 1/2", 1", 1/2"
from what I read the GE panels should be fairly obvious if the spot won't take it, then you wouldn't be able to put it there?
This is unlike some of the other brand panels where you can still put Non current limiting version of breaker to get around the issue. Not that I planned to do that. I just wanted to know which spot can take tandems
Getting the listed breakers is fairly easy to figure out from the original breakers.
