Panel lights
vette-kid
Navarre, FL
Had anyone used something like this that they can give feedback on? Are they worth swapping out my florescent fixtures with something like this? I have three fixtures and these would be easy to swap in. Not looking to paint cars in there, just need more light than I'm getting now without going too crazy.
Sent from my Moto Z (2) using Tapatalk
mike93lx
Richmond, VA
They will generate a lot of Glare if your ceilings are low.
A friend has one wimilar with 10' ceilings and is happy, but his expectations were reasonable.
mike93lx
Richmond, VA
Better than nothing, but not nearly as good as a few strip lights.
How about swapping the Fixture for an outlet and using a few plug in 4 footers?
Shiftless
East Bay SFO
The best “panel lights” I’ve seen are what’s referred to as edge lit led’s. They are only about one inch thick so they sit very close to the ceiling.
I have a few in a basement room with low ceiling height and they are great!
But up you’ll get more light, more evenly distributed than the ones you posted, at a lower price with 4 foot long tubular led fixtures.
V
vette-kid
Navarre, FL
I've got some of the tube fixtures. Honestly, they have been a pain. Lights keep failing, cords come loose and they aren't on a switch. I suppose one could wire and outlet to replace the old fixtures and that would solve the switch issue.
Shiftless
East Bay SFO
That’s exactly how I did it for 5 of those 2 tube fixtures over a 10x20 work area in my garage. Don’t forget to provide required GFCI protection for outlets/receptacles even if they are on the ceiling.
Shiftless
East Bay SFO
Still lots of shadows which is unavoidable with anything that is a single light source.
Sure, it’s more work, but a properly designed array of lower intensity fixtures spread out on the ceiling would be WAY better.
Rewind97
Mississippi
I bought one the WalMart had on their "As seen on TV isle" and it's pretty good in my garage, so I went back and bought one for my utility room. That one would not work, returned it for another one and it's working fine, I like them. 10 foot ceilings in my garage and utility room.
V
vette-kid
Navarre, FL
I would use three. You can always do more work and get better results. sometimes that's not the goal. A mix of simplicity and "good enough" is generally where I'm at these days.
