I have an outdoor breaker cabinet (Zinsco) / meter socket combination. The indoor panel used to be a fuse box, but was converted to a breaker box. The wiring is as shown in the image. There is a breaker switch on the outdoor panel and also a main breaker on the indoor panel. (The outdoor panel has several other brekers not illustrated, that will eventually be relocated to the indoor panel). The only wires from the outdoor breaker panel to the indoor one are the two main legs and the newtral leg. The neutral is connected to the same bus bar that the ground is connected to (that goes to a ground rod). The indoor panel has the neutral and the ground bus bars connected with a bridge. My question, is this correct? Or should the neutral bar and ground bar be separated (by removing the bridge), and the neutrals all connected to the neutral bus bar, and the grounds all connected to the ground bus bar. If separated, should the ground bus bar be bonded to the cabinet with the bonding screw? And should the ground bus bar then be connected to --- where?
Later this year the existing service entrance will be re-located due to building an addition to the house. When relocated, the Zinsco panel will be discarded and there will be only a meter socket (no breakers). Local code does not require an outdoor disconnect - apparently the fire department simply removes the meter should a disconnection become necessary.
Thanks for the assist!
