Paper ring shims, where to buy?
Close by
I’m rebuilding an old Craftsman drill press milling table and need to replace the paper shims on the adjustment shafts, specs are 1” x 1/2” and 1/64”. Anyone know where to buy new ones, McMaster list some that are close but $15 for 10 seems crazy for a few paper washers.
Thanks all
ducksface
So, they're paper?
I don't know...but I think I'd find a way....
Are they paper for purpose or for cost?
Soda can stock makes good shim material.
So does paper... Oh, wait....
And
1/64th might only get you close to right.
It might be 3/128ths or 1/83rd.
You can get heavier and lighter weight paper at staples. 20# is light stuff, 80# is resume weight.
R
Close by
Thanks, but they are a kind of special hard wearing non metallic “paper” but probably not paper at all, they need to hold up to oil and shaft turning without falling apart. Anything soft will introduce backlash into the feed. Could use a metal shim, but the originals were intended to give some lubrication.
MShaw
York, Pa.
Try Multipurpose Flame-Retardant Garolite G-10/FR4 Sheets from McMaster Carr. Start at .005" thick and go up from there.
4xdog
Santa Fe, NM
I can offer a few observations and suggestions as a member of our community with a degree in paper science and engineering and having spent 40+ years in an around the industry...
Seems like it would be easy-peasy to use a compass and either scissors or a sharp blade to cut the ring shims you need.
Paper is pretty resistant to oil. It's water that breaks the bonds holding it together. And even those bonds can be made quite durable by using wet strength grades. Think packaging like beverage carrier board (typically 0.020", more or less). There are many other wet-strength grades -- labels, coffee filters, some paper towels, to name a few -- but the paperboard grades are probably most like what you'd need. A grocery paper bag could be a good thinner caliper wet strength stock (probably 0.012", more or less).
Even without being a wet-strength grade, I'd still think solid paper or paperboard (not corrugated). Better to use brown or white rather than recycled gray for strength.
Something like a business card or pharma packaging might be good lighter grades (say 0.010"). Office printing/writing grades, such as a copier paper as noted, could be a good thin stock (probably around 0.005").
I'd saturate a non-wet strength paper with oil to give it some resistance to water or humidity.
Gasket papers are available as mentioned. McMaster-Carr has a selection. They're almost always wet strength grades and often saturated with rubbery latex resins. I don't think you really need that for what you're trying to do.
R
Close by
Thanks all, seemed like an obvious question I guess :lol: I’ll knock up a few from some paper, certified grocery bag sounds like perfect material! was thinking I’d be able to get a few for a few cents somewhere, certainly not paying $15 for 10 little rounds of paper. Appreciate the paper experts weighting in to help :rocker::bounce:
bugnut
Central Ohio
South Bend Lathess had a paper gasket between chuck adapter plate and headstock. This was done so chuck can be removed and not be rusted together. A cheap set of HF hole saw with the teeth machined off and a beveled edge or a muffler adapter make good punches for cutting paper shims. I like the paper from a 3x5 card or larger card stock.
