Paramount Table top propane Heater ?
trooper1954
Salmon Arm, BC, Canada
Hi All,
Excuse me if I've put this in the wrong section....couldn't see another appropriate one.
I have a question about the above captioned heater....its almost brand new, just fired up for the second time.
The issue is twofold....not sure if the pilot light should be quite large after the heater gets going?(pic attached)
Secondly, the adjustment between low and high makes absolutely no difference to the blue flame....I'm thinking the flame should get larger?
There are no obstructions to the gas flow that I can see....the only factor that perhaps influences these questions is the fact that the 20lb cylinder is just in its last third.
Probably a strange question, but hopefully someone can help.
Thanks
58Yeoman
Central IL
I have a weed burner that runs off a one pound cylinder, and after a while it refuses to stay lit. Those little bottles need a lot of heat to keep the propane 'boiling' to turn to gas.
