Parking Assist/parking Aid
BoostAddiction
Western North Carolina
I just changed out most of the cars in the Garagenous Zone, and the new ones are both longer than their predecessors.
The 2 parking slots dedicated to the daily drivers are not very deep, and I've aggravated the situation by putting a drill press and a press/brake/shear in front of them.
All that means I need to become much more precise about pulling in enough to clear the door in the back, but not too far in front, to avoid the tools there.
In addition to having to be more careful about the front/rear positioning, I also want to help with side-to-side positioning, so opening doors is less of a gymnastic exercise when one car is too close to the other.
So what have people done and liked in terms of devices to help drivers park in just the right place?
I don't want hanging tennis balls, have tried the yellow plastic wheel stops and didn't like them, and even had a kind of laser once long ago.
What works best for the fellow GJers?
SLYDIT
im about to make some ultrasonic parking sensor traffic lights for my garage using an arduino board. pretty electronics intense but you can buy consumer versions..
(skip to 1.40 )
soj
North Georgia
This works for me. The base is 1/8" plywood, (32" X 12") the first crossbar is 3/4" thick X about 1 1/2" wide, it is to let you know you are getting close to the double 2X4 stop. You can feel the tire go over the 3/4" piece, then just let it roll against the 2X4s. No need to tape it to the floor like the aluminum or plastic ones in the above post. The key to it not moving, is the tire locks it in place when it is on the 1/8" ply before it pushes against the first crossbar. I can just pick it up when using that area to work in. The black angels marked on the floor let me put it back in the exact same spot.
This works well for a rear drive vehicle. A FWD might tend to push it back when you start to back up. Never tried it, everything I have is RWD.
-JP
BillK
Beautiful Southern Maryland
Boost,
I think I would rather have something hanging from the ceiling rather than something on the floor to trip on when the cars aren't in the garage. We have a plastic flower on a string that my Wife uses. Her 84 Riviera is longer than the Tahoe :)
TAMPAGT07
Palm Harbor, Fl
I use the old tennis ball... My wife has the tennis ball also...(The ball doesn't stop her, but the workbench does...) :mad:
soj
North Georgia
Another reason to put something on the floor that will be hard to ignore. Just don't glue or tape it down so you can move it when it is in the way.
-jp
wssix99
Chicago, IL
I tapped a cheap laser in to the light bulb power of the garage door opener and used that beam to line up the car as I pulled in. (You can also do the same thing, shot across the door opening to tell when your bumper is clear of the door.)
38Chevy454
Cincinnati, OH
The one homemade by soj, or the purchased one by BeachBoy both seem to be an easy solution. Simple enough to lift it up out of the way.
Stevie-Ray
Michigan's Sunrise Side
Only in the last month has this become a problem for me. Just got a new Flex, and kinda want to keep it clean and out of the snow. Parking it next to my Lightning with all the **** included in the garage from the move has become a daily ritual, so far, of folding the mirrors, pulling it betwixt the L and the far left side of the door, of course favoring the door, turning the wheel slightly to the right when I get in halfway, and then lining up my eye with the second bubble of the level that's sitting on my work bench. Cleaning out the garage IS NOT going to start with the bench.:)
