partially covering a switch box
mike93lx
Richmond, VA
I have a 3-gang box at my house's entryway with only two switches. I've had a cover plate in the third opening for a while, which works fine, just doesn't look great. I've thought about installing an outlet in the extra space, but I just don't need to plug things in often enough for it to be worth it.
I'm planning to install some wainscoting with a hardboard panel covering the existing drywall. Can I cover up 1/3 of the box with the hardboard and then use a 2-gang cover or is that not kosher?
CJ7VFR
Central New Jersey
I you don't want to go to the trouble of changing out the box to a 2 gang box, you could always put a third switch in the unused spot, and buy a three switch wall plate. The third switch can be left unused until such a time as you think of something else to control.
Only you (and your family) would know the third switch is not hooked up to anything.
And it will cost you about $10 to buy a new switch and cover plate.
Jim
mike93lx
Richmond, VA
Jim
i already have a three switch plate on it with a blank cover. It's not a gaping hole right now.
CJ7VFR
Central New Jersey
You could also put in/wire in a simple "Night light" type device in the empty position. This would give you some light in that location for when you come home and the house is dark.
Or even a motion sensor in the empty spot to turn a light on in the entryway.
Jim
mike93lx
Richmond, VA
Jim
good ideas, I've thought about stuff like that, but we come in via the garage, so a nightlight isn't necessary and the entry way is open to the living room (split entry ranch), so a motion sensor would probably be more annoying than helpful.
I can't remember what was in there when we bought the house, but i think there were two slots taken up for a timer on the outdoor light plus an override switch. I've since replaced that will an astronomical timer that has an integrated override, hence the extra slot.
maybe it's worth ripping out the box and replacing it.
PressOn
Wisconsin
Well, I can't post a picture or a link.
So, search Amazon (or Google) for:
"Smooth White Three Gang Wall Plate - Two Toggle Switches One Blank"
and you will come up with another option.
Good luck.
mike93lx
Richmond, VA
Is that what you meant by a blank cover?
Yes, if the nomenclature was misleading or confusing, my bad.
Why not? It would function like an offset mud ring.
https://www.garvinindustries.com/co...vice-rings/one-gang-offset-device-rings/52c11
OP, how thick is the wainscot? Maybe you can use some sort of mud ring.
The hardboard around the switches will only be 1/8. Just installing it to cover some imperfections in the wall.
mm08822
AntonLargiader
Charlottesville, VA
His existing surface is drywall so the box may not be flush. Is your objection that it is difficult, or that it's not allowed?
Mike, how flush is the existing box to the drywall? I think code allows it to be up to 1/4" recessed.
mike93lx
Richmond, VA
Not certain, but most of the boxes have been recessed at least 1/4". House was built in 1970.
mm08822
1/4" is the limit for non-combustible surfaces - which drywall is. Recessed is better than protruding so I think most favor a slight setback.
Once the OP adds wainscoting, the surface becomes combustible and boxes need to be flush to the surface.
I would say it is not allowed as I don't believe a listed cover like that exists - unless of course we are talking cover plates which the OP doesn't want anymore.
One could easily be made but it would not be listed.
mike93lx
Richmond, VA
Interesting, thanks.
Might be best to cut the old box, patch the 3rd gang and install an old work box once the new paneling is up. That solves the sizing and "flushness" at once.
An aside, since fire code is being discussed...on the ceiling of an attached garage, which requires type-x, can one install box-less wafer led's? The ones that you cut a 4ish" hole and snap in the fixture? If yes, is there a qty or surface area restriction?
Norcal
Crazyjake8493
Upstate NY
If you already have a switch blank there, it sounds like the problem is already solved. If yiu really don’t like it, your options would be a dummy switch, nightlight, or USB receptacle and put a little shelf above or below it for charging phones or a small flashlight. Or remove the box and install a 2-gang box.
checkthisout
Is this what you have already? If it is, stop trifling. Any solution other than this requires box tear out and replacement.
Tearing the box out would be easy as your wainscot will cover up the hole you made and a remodel box will pop right in.
View media item 91130
mike93lx
Richmond, VA
No, i have a three switch wall plate with a blank switch filler plate. But essentially the same result, neither look good
AntonLargiader
Charlottesville, VA
Were you thinking of running the new switch plate over the wainscot? Or cutting it out so the switch plate was on the original wall and the wainscot wrapped around it? I’ve seen it both ways.
The first option is more work because of all the depth mismatches and it would probably be easier to just replace the box. Way better looking, though. The second way I can see covering the third space with a metal plate under the wainscot. It’s gotta be safer than the wooden switch covers that are sold and used everywhere.
mike93lx
Richmond, VA
I want the plate on top of the hardboard, so i'll likely cut out the box and replace with an old work
